Old 11-10-2010, 11:59 AM   #1
Gadoozle
God Bless America
Gadoozle's Avatar
Moving the Gas Tank
Hi there everyone,
I have a 1972 C10, is there any way to get the smell of gasoline out of my cab besides moving the gas tank? I wouldn't mind moving the gas tank, but I wanted to know if there was another way to at least reduce the gas smell.
Thanks!
1972 Chevrolet Custom/10...my first truck and first project.
Semper Fidelis
Gadoozle is offline   Reply With Quote
Old 11-10-2010, 05:27 PM   #2
Sammy
Re: Moving the Gas Tank
You can get a new gasket for a couple of bucks or get some gasket material to make your own. Pull the seat, remove the sending unit inspect the tank for possible external leaks. Put a new gasket under the sending unit assy and insure the unit is centered properly. Since you have a 72 check the vent line for being tight. If you have any rubber lines on your vent line they could be the culpret..
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL"
"You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig."
ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629"
Sammy is offline   Reply With Quote
Old 11-10-2010, 05:30 PM   #3
Fitz
There are several reasons for the smell...the rubber hose between the tank outlet and the chassis hard line could be leaking or it might be the gasket on the fuel outlet/sender. I think your tank has an EEV hose coming off the fill neck and that could also be leaking. Mine just had condensation build up in the bottom of the tank and rust put a couple of pinholes in the tank which really didn't leak much but did cause a smell.
I just couldn't stand the idea of driving around with 20 gallons of gas inside the cab with me so when the tank started to smell I moved it out behind the rear axle.
Fitz is offline   Reply With Quote
Old 11-10-2010, 06:06 PM   #4
Gadoozle
God Bless America
Gadoozle's Avatar
Thanks Sammy and Fitz, I will inspect the tank for tiny holes and I'll check the vent line. When I eventually get the bed and the cab off of my truck, I will most likely move the tank. I agree, Fitz, I would not like to be T-boned with 20 gallons of gasoline six inches from my back.
Semper Fidelis
