Old 11-10-2010, 12:03 PM   #1
budnikguy
budnikguy's Avatar
67-72 body on 73-87 frame?!
Ok, I know everything can be done, but, I want to be realistic here. I am looking at a '73 C30 frame and my mind started brewing throwing a 67-72 cab and front clip on it and throwing a flatbed on the rear. I am pretty sure the cab would just need the mounts re-located, but what about the front? How similar is the front frame horns of a 73 to a 67-72? Searched a little bit and did not find a real answer...any help would be appreciated. Thanks
Adam
budnikguy is offline   Reply With Quote
Old 11-10-2010, 12:58 PM   #2
GruntMoanCough
GruntMoanCough's Avatar
Re: 67-72 body on 73-87 frame?!
Rad support mounts just need to be moved back.
My goal in life is to be as good a person as my dog already thinks I am - Unknown
GruntMoanCough is offline   Reply With Quote
Old 11-10-2010, 01:14 PM   #3
sleepingbag
sleepingbag's Avatar
With a little fabbing its really not too difficult. My truck is this way, done by PO and he did a really good job.
1967 GMC 3/4 ton Fleetside
350 ci Chevy
I'd rather do it myself and spend the extra 500 dollars
sleepingbag is offline   Reply With Quote
Old 11-12-2010, 11:17 AM   #4
budnikguy
budnikguy's Avatar
thanks for the input guys...anyone else have experience with this?! Pics would be great too... thanks again!!
Old 11-13-2010, 01:05 AM   #5
54Caddy
GM Addicted
54Caddy's Avatar
what else does this involve very interested i can get a 73 on up frame easliy but having a hard time to find one older for my dads 68. So all that has to be moved is the radiator support mounts??
..Mac’s Garage..
73 GMC, 54 Caddy, 2010 Silverado, 68 C10 RIP DAd
My 73 GMC Truck Build Pic
2010 Silverado 4/6 on 24s
IG:MacsGarage
54Caddy is offline   Reply With Quote
Old 11-13-2010, 07:36 PM   #6
dyrt
i don't have a later frame handy but when i last looked at one i took note, since i had the same thing in mind, that the rear cab mounts are inside the frame rails instead of outside like the 67-72. if i had one around i would be more than happy to snap a picture, perhaps if you take a look in the 73 and later thread and search for frame pictures you will find some. i didn't get a tape to measure the width of the front mount centerlines nor could i measure their relationship to the front wheel center. the frame rails don't look ridiculously different so maybe, if you can score a set of front and rear mounts from someone, you can try to fit them to the new frame to accept the earlier cab. if you are a fabricator, i could only imagine it wouldn't be that hard. from what i have gathered, some people adapt the later stepside beds to the earlier frames so i am sure adapting the earlier bed to the later frame must be in some way possible. this is all, however, speculation.
Mike
dyrt is offline   Reply With Quote
