Old 11-10-2010, 01:04 PM   #1
JetForceF22
JetForceF22's Avatar
1995 Silverado 1/2 350->1995 454 TBI swap
Hello everyone, I'd like to thank everyone in advanced for any help they can give,
I'm looking on buying a used 1995 454 TBI for my 95 Silverado which has a 350 with 290,000 miles. The 454 is complete, serpentine system manifolds, TBI intake and heads, wiring harness and computer, pretty much plug and play. Here are my questions however before I go ahead and buy the motor.
Are the frame mounts going to be the same for the 454?
I read the 4L60E and the 4L80E have the same bolt pattern, so they should bolt up fine; but will the PCM need to be flashed and reprogrammed for the 4L60E anyways?
1/2 Tie-rod front end suspension enough for the heavy 454?
Any other issues that I've missed that I should think about?
How many tires will I burn off!
-Paul
1972 3/4 Ton Cheyenne Super, 350ci 650 cfm Edelbrock 4bbl Performer AVS, Edelbrock Torquer intake manifold, Headman Longtube Headers to 2 1/2in cutouts to 3 inch flowmaster super 40's true dual. 4.10? Rear SM-465/205 transfer case. Now this one is busted!! http://s59.photobucket.com/albums/g2...k/1972 Pickup/
1995 K1500 Silverado 5.7L 350 TBI with 1in swirl torque spacer, Flowtech shorty headers, 3 inch collectors to y pipe going to 3in highlfow cat converter, single offset passenger side outlet, full 3 inch setup from collectors. Edelbrock High Flow 255LPH/67GPH Fuel pump, adjustable fuel pressure regulator and gauge, running at about 18psi. 3.73 Rear 4L60-E 4 speed auto (Rebuilt)http://s59.photobucket.com/albums/g2...1995%20Pickup/
JetForceF22 is offline   Reply With Quote
Old 11-10-2010, 04:42 PM   #2
Chevy350V8
Semper Fi!!!
Chevy350V8's Avatar
Re: 1995 Silverado 1/2 350->1995 454 TBI swap
Well i can awnser the last question: How many tires will I burn off! And the awnser is..... ALOT if no ones looking! Good luck on the swap.
Brandon...
"IT ONLY TAKES EVERYTHING YOU GOT!!"
Semper Fi
Chevy350V8 is offline   Reply With Quote
Old 11-10-2010, 09:07 PM   #3
Colt Cobra
that 454 will shred that 4L60 if its stock. I would recommend a 4L80 swap
Colt Cobra is offline   Reply With Quote
Old 11-11-2010, 01:36 AM   #4
JetForceF22
The 4L60E is not stock, has been rebuilt (just about 10k miles ago) with a new torque converter, bell housing, and a shift kit.
Do you by the way know if I would need to reprog the pcm to tell the computer its running off a 4L60 and not a 80?
Old 11-12-2010, 01:54 AM   #5
bwood
bwood's Avatar
Yes, a reprogram will be necessary. The 80 uses different gear ratios than the 60 and will need to hang in 1st gear longer than the 60. Shifting is all electronic and needs to match the trans.
I also hate to break this to you, but the 7.4 will eat up your 4L60E if abused. A basic rebuild and shift kit isn't going to cut it. The internals should be beefed up to handle the additional torque.
2013 Ford F150 FX4
2006 Chevy Silverado 1500
1982 Chevy C1500
2020 Ford Explorer Limited
2008 Ford Escape
bwood is offline   Reply With Quote
Old 11-12-2010, 02:49 AM   #6
JetForceF22
Yeah I figured that. I'm not sure if the transmission was beefed when it was rebuilt; I know the guy that rebuilt it def made it much better then it ever was stock, but I cant say for certain.
And Thanks for the info as well bwood; I haven't purchased it yet because I wanted this feedback before I made any decisions
Old 11-12-2010, 07:27 PM   #7
tommie
97' Tahoe 2dr/2wd
tommie's Avatar
you should use a 4l80 or a th400 with the bbc.....
tommie is offline   Reply With Quote
Old 11-12-2010, 09:31 PM   #8
bwood
bwood's Avatar
It shouldn't be that hard to find a good 4L80E to put behind the 7.4. Maybe a swap for your existing powertrain? I believe you will also need the slip yolk for the 80 as its bigger than the 60.
2013 Ford F150 FX4
1982 Chevy C1500
2008 Ford Escape
Old 11-13-2010, 01:47 AM   #9
getbent
dont know if the frame mounts will work , but there was know way i was gonna waste my time with a 4l60e I went with a th400, just my 2 cents, good luck on the build and even more luck with all the little hurdles you will face , but it can be done so do it and good luck!!!!
http://67-72chevytrucks.com/vboard/s...90#post4292390
getbent is offline   Reply With Quote
Old 01-01-2013, 06:29 PM   #10
chevdog21
Yes the frame mounts will work I just put 454 into my 1995 gmc long box reg/cab 2wd. The 454 jroped in with out any problems bolted up to the 4l60E but Im going to trade it out later for 4l80E just more so need to get it running so it can get the truck painted the only thing is the exhaust is a litlle dif but what ever.
chevdog21 is offline   Reply With Quote
350 to 454 tbi swap
