70+ ( Old Skool Club )
![]() Join Date: Nov 2003
ECE Gas Tank Install Question
Has anyone installed ECE's rear mounted gas tank. I want to do the install on mine myself and am wondering if I need a flaring toll ( they are on sale this week at a local parts store) to flare the gas lines before I hook it up.
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
![]() Join Date: Jan 2009
Re: ECE Gas Tank Install Question
i used all stainless steel lines and an fittings for mine
65 Chevy C10 Short Fleet BBW 6.0L/4l80E 68 Chevy C10 SWB 6.0L/4L80E 84 Chevy C10 SWB 5.3/4l60E QA1 Suspension |
Are you saying if you use ss fitting and line you do not need to flare the ends .
1969 Short, Fleet, and Beat
I will take picture of what I done tomorrow and post for you. it is braided stainless steel hose with aluminum ends and fittings from summit
#6 | |
In streight lengths from 1' on up to about 5 or '6' with flairs and threaded male nut allready on them. this line is hard er to shape and ya need a tubing bender for tighter bends. The other option is a coil of softer fuel line that is a little easyer to bend by hand, it comes in 25' lengths, probably 20' and 30' lengths as well. This stuff ya need a flaring tool for so you can cut it to length, ya need to buy the threaded flair nut, slide it on then use the flaring tool. I plumbed in my tank using the streight length stuff, i used 3 pieces of varing lengths and custom bent each length, used female couplers to thread them together
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's Last edited by swamp rat; 11-11-2010 at 02:33 AM. |
[ATTACH][ATTACH]Attachment 654986[/ATTACH][/ATTACH]
this is how i decided to do mine. I cost more but i think it was easier because i did not have a bender or flaring tool
65 Chevy C10 Short Fleet BBW 6.0L/4l80E 68 Chevy C10 SWB 6.0L/4L80E 84 Chevy C10 SWB 5.3/4l60E QA1 Suspension Last edited by ms2335; 01-07-2011 at 08:13 AM. |
#8 | |
Which ever way you do it definantly use enough hanger loops to keep the line from chaffing against anything.
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
there is a small red pre filter and an inline fuel pump. I will be running efi. I haven't installed my main filter yet and as the previous post said put plenty of clamps to hold in place. I will be adding at least one between each one I have installed now
