Manual Throttle Control Knob on Dash
Can someone out there post some pictures of how the manual throttle control cable and bracket mount to the carb? Thanks.
![]() Join Date: Sep 2010
Re: Manual Throttle Control Knob on Dash
you talking about a manual choke?
Nope. I'm talking about the optional manual throttle control that is located on the dash right below the wiper knob. Its a screw type knob with a worm gear that pulls or pushes a coil wrapped metal line like a heater control line.
I dont think it mounts to the carb. i believce my 67 mounted to the throttle lever that mounts to the firewall. 71 and 72 may mount to the carb because of the cable throttle. I already removed mine so i have no pictures. sorry.
Roadtrip!
![]() Join Date: Feb 2003
What year truck? The early ones connected to the carb and the 71 72 connected to the pedal assy i believe. Maybe someone can clarify that.
67 gmc custom lwb dakota truck. Sold...And bought back 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
I don't know what year it came out of, but I'm putting it into a 72. I don't think this one was meant to connect to the gas pedal linkage because of the length of the cable. The cable is clearly long enough to go throught the firewall and reach the carb.
Here are some pictures of the cable. Its the one on the left in the first picture.
GMC with Blue Plaid
Here is a picture of the Manual Throttle on my 72. It looks like it may have been connected to the gas pedal arm at one time. You can see the hole where it was attached at the top of the arm. A PO must have disconnected it at some time because it does not work. This has always been somewhat of a mystery to me. Hope this helps.
Current: 1972 GMC Super Custom 1500 402 < 73K Orig MI 2015 GMC Canyon SLT(Daily Driver) Previous: 2008 Chevrolet Colorado LT 2.9L I4 1988 Chevrolet Suburban Silverado 10 350 < 60K Orig MI 1984 GMC S-15 2.8L V6 1976 GMC Sierra Classic 2500 Camper Special 350 1980 GMC High Sierra 3500 Dually 350 4spd 1974 Chevrolet Cheyenne Super 10 Shorty 454 (Was my Dads, I wish I still had it) 1969 GMC 910 250 I6 4spd |
Lehsuper1500 - That does help me some. It tells me that the cable and bracket on mine is different from the setup that connects to the pedal arm. I guess that means mine is supposed to connect to the carb.
Everyone - Thanks for the replies and keep em coming! |
#10 | |
The Older Generation
Nope, yours connects to the pedal arm too. The cable and bracket you have is the early style. I am sitting here with one in my hot little hands. It has a bracket just like yours and it is bolted to the pedal arm. The thing you have to remember is that on the early trucks the arm that the throttle rod connects to is on the outside of the firewall and the later trucks it is on the inside of the firewall. The throttle cable connects to the arm on both of them. LockDoc
GM ONLY BABY!!!
What exactly does it do or what is it's purpose?
2 wrongs don't make a right, but 3 lefts do. 66 Chevelle Malibu 406ci, 573hp, 10.99@121mph 96 Chevy Silverado Z71 72 GMC 1500 Super Custom LS 6.0/4L65 on airride ![]() ![]() http://www.cardomain.com/ride/707879...mc-c-k-pick-up |
You could screw it out so the truck would crawl along slowly. This way one person could load/unload stuff like bales of hay. Also, if you were stealing watermelons you could load a lot of them without having to carry them very far...
![]() Oh, you could pull it out a little to make the truck warm up faster on cold mornings too. LockDoc
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 11-11-2010 at 01:00 AM. |
#13 |
![]() Join Date: Jul 2010
The vernier throttle was also used for PTO operation. We had one in a tow truck.
JB from AZ 1969 Chevy Sub K10 1957 Chevy 3200 1962 VW Beetle 1957 Willys CJ5 ![]() |
#14 |
Wish I could help... my truck used to have a throttle on it until some idiot threw it away while he was taking the truck apart. Take a guess who that was... c'mon, take a guess.
![]() It did indeed connect to the throttle lever inside the truck (71-72). In the pic, it shows that it went up and over the w/s wiper motor before heading to the gas pedal. |
