11-10-2010, 11:18 PM | #1 |
Help me select the right welder
I am trying to make a BIG decision, selecting my first welder. I know you get alot of these threads...BEST welder, help me choose a welder etc, sorry for cluttering the servers, but I am totally clueless here. Im a healthcare professional, and I LOVE cars. My profession doesn't allow much free time and I never had the opportunity to take vocational classes, as my parents made me always take pre-college biology, chemistry, math etc.
I am going to be doing the typical bodyparts (repairing floor pans, filling in body rot, fabricating, some frame work, etc). I also "think" there might be some utility in being able to weld aluminum. I know I had to modify the oil pan on my TBSS and had to have someone else do it because neither myself or my friends could weld aluminum. You guys could probably better advise me on other applications of aluminum welding on these types of projects. My gut thought is instead of getting a small welder that has limited application, buying a "decent" welder that has "many" applications, so I don't have to turn around in upgrade soon after an initial purchase. You guys tell me, is my thinking correct or not? The 2 units im thinking of is Millermatic 211 auto-set with mpv vs millermatic 252. If the cheaper unit would be sufficient then great, but you all have the experience, so I am relying on your knowledge and opinions. Thanks, Brad
2007 TBSS 418ci AI CNC 243, Futral cam, ARH headers, RPM VI tranny, Vig 2800, 430awhp/426awtq 12.1 @110 2002 Camaro SS 346ci Heads/Cam/Intake ARH headers M6, Koni, UMI, magnaflow, DMH, Meizere, ATI, 456rwhp/414rwtq 1965 Chevy C-10 Stepside, 355, TH350, 3000 coan stall, 4.10...Going under the knive! http://www.hubgarage.com/mygarage/profile/28922 |
11-11-2010, 12:20 AM | #2 |
Re: Help me select the right welder
Your definately looking in the right neighborhood. A miller is always a solid choice. Bigger is generally better. The better the welder you buy the more uses it will have. If you get a welder capable of running a spool gun you can weld aluminum. The best choice for welding aluminum is a tig welder but that is a whole different ball game. The 211 is probably all you will ever need. It welds up to 3/8 steel. You will likely never use it for anything that thick especially in automotive applications.
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member. |
11-11-2010, 08:52 PM | #3 |
Thanks Cableguy, Im leaning in that direction right now... anyone else have different input?
11-11-2010, 09:24 PM | #4 |
Hollister Road Co.
The 211 should do well for what you want. The 252 is a bit of over kill unless your going into the restoration biz.
11-11-2010, 09:27 PM | #5 |
with out dout the Millermatic 211 is a GREAT welder...
Measure with a yard stick Mark with Chalk Cut with a torch Built it yourself, don't count on others to to do it for you or with you. It will never get done |
11-11-2010, 10:24 PM | #6 |
I have one of these migs and a plasma cutter from same company.
http://www.htpweld.com/index.htm excellent custoner service too if that means anything but Miller is a good machine also. Last edited by HOGDADDY; 11-11-2010 at 10:25 PM. |
11-11-2010, 11:18 PM | #7 |
I bought a Miller 212 3-4 years ago, Very good machine. Way better than the Hobart I had.
11-14-2010, 02:17 AM | #8 |
If your willing to spend the money the miller is the best out there I personally have the 187 Hobart machine and it does a great job has done everything I've asked it to and about a third of the price you can run aluminum wire trough your machine you just have to reverse the polarity in the machine witch is easy but you have to keep your lines as stright as possible other wise your wire could ball up on you in the line (spool gun is beter for aluminum in mig aplication but another expense to add on) but for welding aluminum tig is the best mig aluminum is very dirty and won't give very good penitration. If your not going to go crazy and use it 8 hours a day for years a Hobart will handle all your needs for the price. Miller is defently a beter machine but unless your opening a shop I don't think it's worth the price differnce
Posted via Mobile Device |
11-14-2010, 02:30 AM | #9 |
Why just compare these 4 wire drive systems.
http://www.htpweld.com/products/mig_...omparison.html For about the same price as a miller 211 you could get this bad boy here http://www.htpweld.com/products/mig_...s/mig_200.html You are paying for the Miller name but is it really the best?? Last edited by HOGDADDY; 11-14-2010 at 02:26 PM. |
11-14-2010, 04:10 AM | #10 |
Just my $.02 but I bought a Panasonic Gunslinger 261 myself. Had it 3years no troubles. The only reason I bought one is I have a buddy that does alot, and I mean alot, of fab work on his farm and he bought one. I had the pleasure of running it before I made a decision. The welding store sells them along with the typical Miller and Lincoln welders. They told me they cant keep the Panasonics on hand as I had to wait 3 weeks for it to come in, and they try to keep 2 or 3 in stock. They also said they have very rarely seen any problems with them compared to the red or blue. I have welded with both and dont have a problem with them myself, although the company I work for has had the 252 into the shop many times and it isnt used that hard. Most people havent heard of them and laugh when they hear the name as I did but I am sure not dissapointed.
Name: Les ---------------------- Couple 80s Couple 70s One 68 |
11-14-2010, 12:41 PM | #11 |
I just purchased the Millermatic 211 about a month ago. Haven't had a chance to use it a whole lot yet but I have been impressed with the limited use it's seen. You can't go wrong buying a Miller.
11-14-2010, 01:42 PM | #12 |
11-14-2010, 02:57 PM | #13 |
Hollister Road Co.
Buy a welder that you can buy the consumables locally at an afordable cost. I have a lincoln pro cut 25 thats a PIA to get tips for and have to order online. My sp175T welder is no problem getting parts for.
Miller and Hobart are both fine welders but my next one will be an HTP due to their customer service. I have their hand held spot welder thats far better than the Hobart spot welder. HTP also has a 90 day return policy. If you buy it and don't like the way it works send it back. Can't beat that offer. |
11-15-2010, 12:16 PM | #14 |
I bought a 211 about 4 months ago and love it. I easily weld anything on my frame and it can be gentle enough on 110V to weld my body panels. I love it, for a grand you can't get a better welder. Never used a 252 but I imagine it has will work great but it has much more power, more then you need to weld up a car.
Trevor "You already said spite" |
11-15-2010, 10:03 PM | #15 |
OK, the Miller 211/212 can do gasless welding...how do you guys feel about this type of welding for our type automotive application? To me that is a real attraction...you don't need gas (which to me seems like a hassle), and IMHO the gas is just one more variable to have to control...
Thoughts? Experiences?
11-15-2010, 10:49 PM | #16 |
you can weld without gas but wled quality is poor and not good for sheet metal. once you set your gas flow you dont change it. gas is the only way to go.
11-15-2010, 11:44 PM | #17 |
argon/co2 mix gas is the way to get good quality welds, gas is going displace the elements in the air you breathe that contaminates welds. with out it youll get porosity, chard welds. from what it sounds like its saying that you can use a flux cored wire, i.e. you wont need gas cause the flux protects the weld. using flux core requires a higher amp requirement from your welder and will be more likely to distort your patch panels. in short: if you were making 4 links and welding in cross-members and some welds that require STRONG welds id say that keeping a spool of flux core (down the road after you get your welding machine)is definitely handy. If your welding body panels or about 80% of your shop chores get 75/25 argon/co2 mix gas. Hope this helps
72 lwb farm truck 86k o.g. miles. 350/th350 89 toyota 3" drop 22r 4spd 2wd |
11-16-2010, 12:00 AM | #18 |
I only recommend using Flux Core wire in windy situations. Using a shielding gas is the way to go on automotive stuff. I prefer 75/25 CO2/argon mix for mild steel, Running 100% CO2 does OK with mild steel.
11-16-2010, 12:15 AM | #19 |
Hollister Road Co.
Use flux core in a situation where penetration might be a problem. Rusty metal, frame work or thicker metals. 1/4" and up or metals that need to be heated prior to welding
11-16-2010, 12:35 AM | #20 |
here ya go everything you really need to know. oh yeah and regardless if it is a lincoln welder article it pertains to the topic
http://www.lincolnelectric.com/knowl...sfluxcored.asp
72 lwb farm truck 86k o.g. miles. 350/th350 89 toyota 3" drop 22r 4spd 2wd Last edited by camjck89; 11-16-2010 at 12:35 AM. |
11-16-2010, 12:21 PM | #21 |
I wouldn't recommend welding without gas, it is nasty stuff to use and the welds leave slag. Gas is easy, set it to 10-15 Lpm and let it rip.
11-16-2010, 03:57 PM | #22 |
Get the gas 75 25 mix it is 100 time beter to use than flux cord I've only used flux outside welding in the wind.. With flux you'll have more prosity to deal with on trying to get your panels preped for body work And if you get the 211 frame work won't be any issue no need to pre heat just bevel it a little weld it and put a fish plate on it but a mig setup us the only way to go on sheet metal and automotive it's the most versatile you can get
11-17-2010, 11:33 PM | #23 |
I used to weld for a hotrod shop professionally on a daily basis would spend 3-6 hours under the hood non stop and I was using a 1982 miller squarewave tig. I loved the machine. For mig I had a nice 210 miller setup in my area it was a very dependable machine I liked it. My current stuff in my personal shop I run a Hobart handler 180 It's a 220v machine but it's really a nice size for moderate fab. You can run flux core if you feel the need. I don't do any personally. My Tig is just a little synchrowave 180sd. I have often wanted to sell it and move up but I don't have enough fab work right now to justify it.
Hobart if I am not mistaken is owned by Miller. I have seen really good deals on their equipment in the past. I can't remember what I paid at the time but I ended up picking it up at a Tractor supply Co. I haven't cared much for lincoln. HTP I have been dying to use their equipment plus it's made right next to my hometown so I have been very eager just lacking funds. |
11-18-2010, 12:50 AM | #24 |
Hollister Road Co.
Hobart and Miller are owned by the same holding company but one does not own the other. They are seperate companies and products. I think the only place you can't buy a Hobart is at Mc Donalds. I see them for sale everywhere.
11-22-2010, 07:53 PM | #25 |
Is this pretty close to what most of you run as far as lpm? The set-up cd I got with my Millermatic suggested to run it around 25.
