11-10-2010, 11:26 PM | #1 |
Modified A-Arms For G-Body
Has anyone modified their a-arms for either a s-10 or g-body frame? I have 2600 firestone bags that I will be installing in all four corners. Pictures would be helpful and what size upper airbag cup did you use. Please post pictures if at all possible.
FAT MIKE My 59 http://67-72chevytrucks.com/vboard/s...d.php?t=400201 My 47 http://67-72chevytrucks.com/vboard/s...d.php?t=386848 |
11-10-2010, 11:59 PM | #2 |
Redefining LowBudget
Re: Modified A-Arms For G-Body
mike check my build theres some measurements and pics of the LCA I did for my truck theres no reason that I know of that it wouldn't apply to any coil front end
1970 C10 CST fleetside 472 ....big dreams little cash... SunShine Syndicate.. Mikes Sandwich Fair Run OCT 8th 2011
11-11-2010, 12:34 AM | #3 |
You dont need to do anything to the upper arms.Your upper bag cup sits in the frame just like the OEM spring did.Cant remember how tall my upper cups are off hand but i have 2500's in an had to do a little trimming off the frame.Depending how tall your upper cup is will determine how much you'll need to cut.
You can use a cups for the bottom also.So guys have plated the lowers to avoid cups I'm on thsi site allot.Just search bagged g-bodys http://www.layitlow.com/forums/index.php?showforum=17 |
11-11-2010, 12:36 AM | #4 |
Oh an mike here's a link to how i did my rear in my cutlass.Check out my signature there where it says "RE"
http://www.layitlow.com/forums/index...owtopic=498541 |
11-11-2010, 10:04 AM | #5 |
Thank you all very much! That website is very cool and has alot of usefull info.
