11-11-2010, 11:29 AM | #1 |
Crossmember question.
I was wondering if the 73-87 crossmember/suspension is a direct bolt-in to the 67-72 C-10 frame? Seems that would be a cost efficient way to get 5 lug/disk brake set up. Also, is one wider than the other?
Danny |
11-11-2010, 12:33 PM | #2 |
Junior Member
Re: Crossmember question.
yes.... you can also just change ball joints,spindles and tie rod ends too..... or take the control arms off the donor along with the spindles and tie rod ends.... its all interchangable...
11-11-2010, 01:02 PM | #3 |
What this dingle berry just said :-)
11-11-2010, 02:55 PM | #4 |
Thanks!!
