Old 11-11-2010, 12:08 PM   #1
ryans69chevy
Will this engine fit?
Would this be engine fit into a 69 chevy c10 1/2 ton? I'm looking to buy a cheap engine that will take a few years to rebuild myself because I want to learn so bad! What better way to start then on a 454 right? I'm just wondering since it says it's from a mid 70's chevy pickup will that fit nicely in my 69. I know I'll have to upgrade the suspension to withstand all the weight. If this is do-able what else would I have to purchase? Thanks!
454 BBC Complete Engine & 400 Transmission - $500
One recently pulled, complete chevrolet 454 engine and turbo 400 transmission out of mid 70's Chevy pickup.
Good rebuildable core, not stuck, did run when pulled. Have short videos of motor running and truck moving.
$500 priced to move.
ryans69chevy is offline   Reply With Quote
Old 11-11-2010, 12:24 PM   #2
Fitz
Re: Will this engine fit?
Originally Posted by ryans69chevy View Post
Would this be engine fit into a 69 chevy c10 1/2 ton? .
If this one fit in my 67 1/2 ton on the stock BB mounts that 454 will fit yours:
Fitz is offline   Reply With Quote
Old 11-11-2010, 12:47 PM   #3
ryans69chevy
HOLY MOLY!!!! That's huge! That thing must purrr....Well I'm just wondering since it said it was from a mid 70's pickup if that would fit in a 69...?
Old 11-11-2010, 12:55 PM   #4
smn69
It will fit. You will need big block engine perches and a cross member for the transmission (depending on the transmission that is already in the truck). These trucks came with a big block option.
smn69 is offline   Reply With Quote
Old 11-11-2010, 01:04 PM   #5
ryans69chevy
Okay. Do you think from looking at the pictures is a good deal for this?
Old 11-11-2010, 01:48 PM   #6
smn69
Really hard to tell. It looks like something was dropped on it. Although 500 for motor and transmission seems reasonable ( especially if you can sell the ones out of your truck to offset the cost a little). Just look for any obvious signs of cracks or major damage.
Old 11-11-2010, 02:20 PM   #7
Shyguy
Junior Member
Shyguy's Avatar
Yep, it will fit. We put a '73 454 out of C-20 in my '71 C-10 that has a granny low 4 speed.
We used the big block motor mount stuff from the '73 and also the fan shroud. It took a little work to get it to fit with headers but it worked out ok.
We paid $500 for the running engine and automatic transmission. The engine went into my truck and the transmission went into my son's truck.
'67 Chevy C-20 short stepper - build complete, 454/SM-465.
'75 C-30 Single Cab DRW-350 small block/NP-435.
'77 GMC-6500 Dump Truck, 427 Tall Deck.
'92 GMC K-3500 Duallie, 454/4L80E.
Shyguy is offline   Reply With Quote
Old 11-11-2010, 03:26 PM   #8
Fitz
The existing crossmember for the trans will work, the frame is drilled for two mounting locations, just move the trans mount to the rear set of holes.
Old 11-11-2010, 04:13 PM   #9
Fitz
No purr....but a very deep growl can sometimes be heard almost hidden in the screech of the tires!
Turning good rubber into white smoke since 1963.
