Air Ride Supplier?
Well, I'm going to open a can of worms here
![]() Thanks for any info. Oh, and let the debate begin. |
Re: Air Ride Supplier?
Give me a shout! I worked for A.R.T for 3yrs as sales/ tech/ warranty so I am extremely familiar with the product and will give you the best deal and product support of any dealer out there... Guaranteed!
Thanks, Jon 805 485 0382 jonm@scottshotrods.com or shoot me a PM |
I am in the same situation you are in. I did not have the funds at the time i built mine for a high end air managment system. I did some homework on the web and even called some suspension shops to help me build mine. Living in Houston Tx I have resources available that some dont. It is really easy to build a control box, wire, and plumb. I researched this site to no end and came up with a setup that is rock solid and cheap. I used hydraulic hose in my system because of the durability, that was the most expense of the system. I went to a local electrical supply a purchased my switches and a aluminum enclosure to hold them. I ran a multi strand wire i bought from a trailer place to wire it. I have about 30 dollars in my controller and it is hand held. Valves are a big expense, bought GC extreme valves from a local suspension shop. I like them because they have a DIN style connector to hold the water out. My build thread EL CHingon in the 67-72 section shows some of the plumbing and wiring. It is not as slim as some others, but it works and since i built everything I know exactly what to look for if or when a failures occur. Pm me for any questions, I am more than happy to help you.
I did my '69 for pretty cheap. I used a 7 switch box off ebay ($30?), then found part of a kit someone else started and gave up on that was valves, Slam Specialties bags, tank and compressor, then I got all my fittings from Granger (brass press fittings), got all my lines from Suicide Doors, then the rest was from Ace.
I think when I was all done I spent about $600 total. 8 valves, 7 switches, 2 dual needle gauges, a tank gauge, and it was all good for air and management. <edit> Ace Hardware, just to be clear.
New Project: 1966 LWB C20 Plans: 1/2 ton conversion Dropmember front Dropmember rear Corvette discs Restored raised bed http://67-72chevytrucks.com/vboard/s....php?p=4295210 Last edited by jimmydean; 11-11-2010 at 02:28 PM. |
be careful when using non D.O.T components this is your vehicle and life your riding on....
#6 | |
![]() I went with all grade 8 hardware, DOT lines and fittings, and used thread sealer (not thread tape) on all my fitting threads. Even though it's more expensive, I will use a manifold next time and make my life easier.
New Project: 1966 LWB C20 Plans: 1/2 ton conversion Dropmember front Dropmember rear Corvette discs Restored raised bed http://67-72chevytrucks.com/vboard/s....php?p=4295210 |
