6 ,7 ,AND 8 "Ralley wheels /Tires
I have amassed a set of 6 ,7 ,and 8 '' Ralley wheels .I am currently running the 6' van Rallies on my 72 truck which look OK. My question is what would be the best tire size to run on the 7 " and 8" on a stock ride height truck ?I will most likely use the 8" wheels but would like your opinions on each in case I go with the 7".
Thanks John ![]() |
Re: 6 ,7 ,AND 8 "Ralley wheels /Tires
Just bought a set of 15x8's myself
Spike ![]()
68 stepside http://67-72chevytrucks.com/vboard/s...0&goto=newpost |
I've got 15x8's with 275/60/15's with stock ride height. They look tough and fill in the wheel wells nicely. here's a pic
Edit: Found some better pics ![]()
Eric ![]() ![]() ![]() ![]() 1995 Ford F-250 4x4 Powerstroke, 342k "Each generation goes further than the generation preceding it because it stands on the shoulders of that generation. You will have opportunities beyond anything we've ever known." -Ronald Reagan Last edited by 67chevylongbed; 11-11-2010 at 11:42 PM. |
Just put on 8's too. I decided on 275/60's on rear, 235/70's on front. Probably should have went with 235/75's on front. I was planning on putting 275's all the way around till the night before, Changed my mind an am still undecided if I went the right way.I have a 2/3 drop also, sorry about the bad pictures, I'll have to get some better ones.http://67-72chevytrucks.com/vboard/a...1&d=1289532148
On stock height, I think a 235/70/15 front, 255/70/15 rear combo looks great.
gonnuts, you did the right thing with the 235's in front. I had 275/60's all the way around for 50,000+ miles, and I disliked them because of the way they pulled the truck around the road when you go over uneven parts. I've got a set of 235/75's now, and the truck drives much more smooth and straight.
70+ ( Old Skool Club )
![]() Join Date: Nov 2003
On my stock height truck I have 235/70R15's mounted on 15 x 8 rallys on all 4corners.
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
Keep them pictures coming guys ,them are nice trucks .I love that orange truck ,I hope someday mine looks similar to that .
I'm running 6 lug 15 x 8's on my stock height 70, with 255/70/15's all around.
![]() ![]() ![]() 1970 Chevy C10 LWB 307 3OTT 3.73 gear |
