newer 250 has no guts.
My original 250 one of the lifters went out. So we managed to get our hands on a newer 84 250. ( I know I know, integral head.. but it was free) Well cant seem to get the truck going past 30 mph. Its the strangest thing. First gear is all fine and dandy.. then second gear will seem to stall out if gassed super fast, if we baby it we can get it into third but it seems like its reving really high and get severe windage? What do u guys think? Any advice would be appreciated thanks.
66 Gmc 1 ton. Long Step 351e V6 69 1/2 CHEVROLET (now a shortbed) LONGBED! ![]() ![]() 61 Shortbed Fleetside 1/2 ton.. in progress Next a 50-53! MY BUILD THREAD http://67-72chevytrucks.com/vboard/s...d.php?t=447926 |
The Older Generation
Re: newer 250 has no guts.
I don't know if you have checked the compression on it but that's the first thing I would do. Plugged fuel filters will cause that type of symptom too. Replace the one in the carb inlet, plus any others you might have. Just some things to check... LockDoc
![]() Join Date: Apr 2001
hows the fuel pump... sounds like it may be starving for gas with load on it...
--Mike
63 C20 2WD, 230/SM420/4.11 73K 68 C30 dump truck, 327,SM425,4.56 66K original 68 C10 2WD SWB Stepper, 250/3-tree/3.73 66K.... Wifes 68 Buick Skylark Custom Conv., 350/TH400/2.56 In our family since '79 69 GMC 1500 SWB 2WD, 350/TH350/3.73 posi... 70 K10 SWB 4X4 4-sp,ps, pb, tilt, buckets, console, sliding back window (Need AC parts) WIP 72 Chevy K20 4x4 350/350/205/4.56 donor 72 Vette 350/M21/3.70 posi, triple black and super fast 84 Olds Cutlass Brougham 350/2004r/4.11 was Dad's |
Oh, and don't forget the fuel strainer sock on the end of the fuel pickup tube. (it's in the fuel tank) LockDoc
#5 | |
Ray
Live more responsibly. Eat lower on the food chain. Eat vegetarians. |
was the condition of the motor known before swap? i'd do a tune up in cluding all filters, i agree sounds like a fuel delivery problem, if the old one ran fine then the fuel tank one should be good but should still check also whats the condition of the fuel pump? maybe its not putting out enough psi to last at higher rpms/fuel loads.
1972 gmc c25 292/sm465 dana 60 w/5.13s 1973 vw super beetle 1600cc/4spd(baja bug) 1974 chevy c60 351v6/np-540+2 speed eaton rear 2005 chevy cobalt 2.2l |
Factory Strippers Rule!
![]() Join Date: Mar 2009
Maybe it's the tranny...
"Feast your eyes on a feast of smoke." 67 Chevy Short Fleet PLAN: LQ9, 4L60, D60 Looking for School Bus Gauges - Help me out! |
^^^ not saying your wrong, but wouldn't a tranny problem have shown up with the previous motor? that being said were any tranny lines hit(auto) or clutch miss adjusted? maybe clutch has enough to hold in first, but as vehicle speed/load increases it loses grip hence the hi rpm sound?
Hey guys thanks for the all the feedback, I think it might be a combination of a lot of things. ( Mostly I was too excited buying my first project truck, that turned into a daily driver) I will try to start from the beginning, maybe you guys have some ideas or input that may help me out. I'm learning so bare with me.
1. Even when I first got the truck there was some lifter noise from start up, always started strong and sounded good ( except for the constant ticking noise) but after it warmed up a bit it went away. 2. The truck ran fine on the freeway up to about 55 then you could feel the tranny area knocking around pretty hard, so I always kept it at low speed. then the trouble started. I lent it to my father in law for a week so he could do some light trailer towing. We'll hes hard on his cars. Drives fast, starts fast, drove my truck around town like he was a teenage boy. Well thats when I got the truck back and the tranny felt like it was slipping in and out of gears. EVEN WHEN IT WAS NOT IN GEAR! I was lost so I let it sit And he borrowed it again. That when I had to go pick him up because the motor felt like it was knocking like crazy, but it felt like it was shifting fine. No high rpm noise, just real bad knock coming from motor. So we pulled it out and replaced it with a 84 250 motor. Leaks a little from the rear seal, but other then that turned freely and was in good shape. Another problem we had was we started pulling smog stuff of the new motor and I know theres some important vacuum lines that were not hooked up, but just plugged. So now thats everything I think. I was thinking of just finding a driveable cheap 350 setup out of a 73-87 pickup and using it to replace the whole drive train in the truck in one big swoop. I dont know, what do u guys think? edit: the current transmission is a 4 speed ( including low gear ) the PO converted to floor shift from column shift. Looks like it was a rebuilt one, he said it was rebuilt, but it could of just been painted.
66 Gmc 1 ton. Long Step 351e V6 69 1/2 CHEVROLET (now a shortbed) LONGBED! ![]() ![]() 61 Shortbed Fleetside 1/2 ton.. in progress Next a 50-53! MY BUILD THREAD http://67-72chevytrucks.com/vboard/s...d.php?t=447926 Last edited by BadaSs_Cal; 11-17-2010 at 02:19 AM. Reason: more info |
