11-12-2010, 01:52 PM | #1 |
Cultural Infidel
alternator wiring ?
Somewhere in the past, a PO changed the alternator to a one wire internal regulator SI 10. I want to change this to a 94 amp SI 12 3 wire. I cannot find any of the original wiring from when it had an external voltage regulator. Where should I look to find the wire for the # 1 terminal? What color is it?
posted via La-Z-Boy -Mark 1972 C-10 Fleetside 350/TH350 PS PB A/C Cab Sadly....Sold 1968 Short Fleet 350/TH400 PS PB Delivered by Fine69 Also sadly Sold! It may be that your whole purpose in life is simply to serve as a warning to others. A man is not complete until he is married -- then he is finished. |
11-12-2010, 01:54 PM | #2 |
Re: alternator wiring ?
See if it was taped back behind the driver's headlight. That wire will be red.
Posted via Mobile Device |
11-12-2010, 02:19 PM | #3 |
Cultural Infidel
I located the old voltage regulator. Plug has 4 wires going in. Looking down at it, the first 2 are cut and gone, the next one is red and I can't tell what color the bottom wire is, but they are both there. Also I found a red wire in the harness that is cut off. I don't know which wire to use.
11-12-2010, 02:51 PM | #4 | |
Here's a diagram which shows the wires jumped at the old reg plug if you trace the wires to the alternator the brown wire goes to #1 and the red goes to #2. Is this a gauge or idiot light dash?
1965 GMC shortwide big window 1969 Chevy C20 long (for now) 2005 Silverado 2500HD Crew Cab Quote:
11-12-2010, 04:50 PM | #5 |
Cultural Infidel
idiot light. Thank you, it works now that I found the brown wire.
