mildew problems
what do you guys do to keep mildew down,have a block garage,cement floor,cars sitting on carpet,still got mildew,thanks for any help jimmie
72,2wd short bed cheyenne,350,350trans,air,tilt,tach,posi 373 gears 70 nova 5.3,350 trans 80 z28 350,350,trans,bought new 03 cat. 06 gmc swb ext cab |
Re: mildew problems
dehumidifier would be good.
![]() Join Date: Aug 2008
Re: mildew problems
Re: mildew problems
got one today,do i want to let it all the time,thank you
Re: mildew problems
I would say run it all the time you have the garage closed up. There is mildew killer that you can wipe the walls down with but if they are bare block I don't know how they will work. I think there is some that you can put in paint for the walls too.
Re: mildew problems
where do you get this at,my walls are painted
Re: mildew problems
I have a block garage, concreet floors, & no issues. I slide big sheets of cardboard under my old truck
http://community.webshots.com/user/hotrodhorn |
Re: mildew problems
Consider why you have moisture issues and address that. Then treat the mold or mildew.
Is water able to drain away from your building? Is your block/cement sealed? I have issues with my house garage that will probably result in me jack hammering up the current slab. Then digging down deep adding the proper rock base. Then adding a vapor barrier. Hope you wont need to do that. Is your landscaping sloping away (down) from the structure? Hows your roof/gutters? Good luck let us know how Its going.
"I feel the need for speed!"... as soon as I am done with my nap. |
I am a Referee of life.
Re: mildew problems
I would do away with the carpet.The moisture has to stay there a while to form mildew and the carpet will stay wet.I run a dehumidifier in my basement constantly,and it's a pain to remember to drain,so if you can put a permanent drain in for the unit do so.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
Re: mildew problems
rug would b a sponge for the moisture,rubber mats are better
having good ventilation both inside the garage and outside is a plus
Re: mildew problems
going to do away with the carpet,and use a dehumidifier,i have no trouble no where but the inside of my cars,i have a seat that sits on a bench,no problem,tools that never rust,i just don't no,thanks guys for the help
Re: mildew problems
Remove the carpet. concrete is porous and the temperature difference will draw moisture from under the slab into the warm space. That is why moisture barriers are installed in all commercial buildings. Without carpet it vaporizes into the air, with carpet it is captured and starts to mildew. Dehumidifier will work to get it out of the air but the carpet will still be damp and mildewing. I have small rubber area pads where I stand at the work bench. I roll them up when I am not using them because even here in the desert I'll get dampness under them if they are left down.
1959 Chevy Short Fleetside w/ 74 4WD drive train (current project) OrrieG Build Thread 1964 Chevelle Malibu w/ 355-350TH (daily driver) Helpful AD and TF Manual Site Old Car Manual Project |
#13 | |
Re: mildew problems
