Old 11-13-2010, 11:36 AM   #1
68ChevyC10-250
68ChevyC10-250's Avatar
Question NV3500 Transmission
Has anyone ever bolted up a NV3500 Tranny to a 1968 inline 6 250cuin?
68ChevyC10-250 is offline   Reply With Quote
Old 11-13-2010, 12:46 PM   #2
raycow
Re: NV3500 Transmission
The NV3500 will bolt up, but here are the major challenges you will have to deal with:
1. You will lose your stock bellhousing mounts. This means you must remove the existing bellhousing crossmember and install a new crossmember farther to the rear.
2. You must convert to hydraulic clutch linkage.
3. All the NV3500s I looked at had electric speedo drives. This means you must either run a Cable-X ($300 +) or install an electric speedo (less than half the cost, if you don't mind the non-stock appearance).
After looking at all that, I ended up going with a T5 instead.
Ray
Live more responsibly. Eat lower on the food chain. Eat vegetarians.
raycow is offline   Reply With Quote
Old 11-13-2010, 12:47 PM   #3
Beat68CST
Beat68CST's Avatar
But, aren't the 4x4 NV3500's cable speedo?
Beat68CST is offline   Reply With Quote
Old 11-13-2010, 12:54 PM   #4
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
I think I read they are both, the cable hooks to the transfer case and it also has provisions for the electronic on the trans. Someone like Clinebarger could best answer your question, but I think I am correct.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 11-13-2010, 03:47 PM   #5
Beuford
Beuford's Avatar
Raycow is right on. I put an NV3500 in my C20 and love it but the changes are needed. I switched to all Autometer gauges but your looking at about $560.00 for all 7 holes. The clutch master cyl and slave are around $100.00 at Auto Zone but if you have the big brake booster locating the master cyl will be difficult. You will also need a front yoke from a Turbo 400 or the 5 speed and the two universal joint cups will require 2 sizes. If you have a short tail shaft now you probably won't have to cut your drive shaft,I didn't need to. Hope this helps.
Beuford is offline   Reply With Quote
Old 11-14-2010, 10:39 PM   #6
68ChevyC10-250
Question Re: NV3500 Transmission
Thanks for all the info, my other question is this, My stater bolts to the cast iron bell housing right now. I see no provision on the NV3500 tranny to mount the stater, how do you get around that?
Patrick
Old 11-15-2010, 04:15 AM   #7
raycow
Use a block-mounted starter. All trucks that came stock with NV3500s did.
Ray
Old 02-26-2014, 08:12 PM   #8
elf w/capital T
I wish I could mount the one i took from the junkyard....the block in my truck 350 doesn't have the holes for the starter!!! ANYONE know of a starter that can mount to the nv3500 bellhousing
elf w/capital T is offline   Reply With Quote
Old 02-26-2014, 08:28 PM   #9
DirtyLarry
Windy Corner of a Dirty Street
DirtyLarry's Avatar
There aren't any. NV3500's were never intended to have a starter mounted to them. You're going to have to drill holes in your 350 to mount a starter
Have fun with that and be careful
DirtyLarry is offline   Reply With Quote
Old 02-26-2014, 10:47 PM   #10
hugger6933
You have a 350 without starter bolt holes? That one is a new one to me, I have been at this a while but I guess not long enough. Jim
hugger6933 is offline   Reply With Quote
Old 02-28-2014, 07:23 PM   #11
elf w/capital T
I do, PO had shaved the holes and a few on the front side of the block!!!!! NOOOWWWW WHHHYYYYY would anyone do that????
