Old 11-13-2010, 04:43 PM   #1
bsteele
Ball Joint Question
I have a 69 c10. I am in the process of putting drop spindles on it. I replaced the ball joints last night with the ones for a '73. The problem I have is this. One side pressed in just fine. The other side started a little out of wack so I started over, and it finally went in straight. But when I went to put it all together today, I noticed the ball joint has a little wobble. You can move the stud back and forth a little and the base of the ball joint will come back out of the hole just a little. I went back to the press and put some more pressure on it, it went in, but still can be worked back out. It comes back out about a 1/16" or just a little more. Did I screw up? It won't work properly like this will it?
bsteele is offline   Reply With Quote
Old 11-14-2010, 09:31 AM   #2
LONGHAIR
Re: Ball Joint Question
I would press it back out and replace it with a new one. No point in doing all of this work and leaving it with a loose joint.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 11-14-2010, 10:28 AM   #3
bsteele
So do you think it messed up the ball joint or the hole in the a arm? I know you probably can't tell without pictures, but thought I would ask.
Old 11-14-2010, 11:55 AM   #4
69 longhorn
I would say you stretched the hole in the arm. Moog offers an oversized ball joint to compensate for the worn hole crazyAl
http://community.webshots.com/user/hotrodhorn
69 longhorn is offline   Reply With Quote
Old 11-14-2010, 12:25 PM   #5
bsteele
That's what I thought may have happened.
Old 11-14-2010, 02:01 PM   #6
c10seconds
c10seconds's Avatar
Moog problem solver should be the answer. If it still has play i've seen them tack welded into the stock arms
c10seconds is offline   Reply With Quote
