11-13-2010, 06:01 PM | #1 |
looking for 12 volt power source
im looking for a twelve volt power source that turns on when the key turns on( its for the electric choke to my carb). anyways, i tried everywhere on the fuse box, and nothing lit up, and the only thing that i can think of that has that feature is the in line fuel pump(its in the frame rails, not the kind on the block). i really dont want to splay the lines to that though, so do you guys have any ideas?
........................ __ ............._______|__\____ ............|_({})______({})] ................(O)..........(O) |
11-13-2010, 06:08 PM | #2 |
Re: looking for 12 volt power source
The two pins in the circle I drew should have power when the key is on.
Make sure that your test light is well grounded as sometimes it's hard to get a good ground up under the dash. I usually hook mine to the park brake bracket. |
11-13-2010, 06:37 PM | #3 |
Hellasick
piggy-back off the radio, keyed-on except when you hit start. The factory did that for the Transmission Spark screwer-upper (disabled vacuum advance except in 3rd).
I keep two MAGNUMS in my desk. One's a gun, and I keep it loaded. The other's a bottle and it keeps ME loaded. I'm Tracer Bullet. (Calvin and Hobbes) This life was a test. It was only a test. If this had been an actual life, you would have received instructions on where to go and what to do. RED meat is not bad for you...FUZZY BLUE/GREEN MEAT is bad for you!!!!!!!!!!!!! BUILT FORD TOUGH WITH CHEVY STUFF--sticker at Goodguys |
11-13-2010, 09:17 PM | #4 |
hey thanks, mr48chev, that worked perfect
