11-13-2010, 06:27 PM | #1 |
1972 K20 power steering swap
Hi I just recently got out of the 79 ford thing and into the whole chevy thing. Got a 72 K20 and it has manual steering. What are my options on what power steering box I can run on this thing? And pump and bracket? Might be a dumb question but I'm still learning about chevys.
Posted via Mobile Device |
11-14-2010, 08:48 AM | #2 |
Re: 1972 K20 power steering swap
I have the same truck wanting to do the same thing. If you need pump,box,lines etc there is a junkyard in MO called Manes truck parts. They deal with 67-72 chevy parts. http://www.manestruckparts.com/ good luck
11-17-2010, 03:32 AM | #3 |
thank you. i have a ps 2wd box i just didnt really know where to start. i know on fords pretty much nothin will interchange!
11-17-2010, 06:13 AM | #4 |
The easy way is to find a doner truck and install the parts from it. Here is a link to a previous thread about installing power steering.
Jim http://67-72chevytrucks.com/vboard/s...d.php?t=423638
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC |
11-23-2010, 03:13 AM | #5 |
do you know what year boxes will fit a 72? ive heard that 2wd will turn the opposite way so you cant use one. but i got a access to a few boxes up to 87.
11-24-2010, 06:10 PM | #6 |
Has to be a 4wd box, any thing 69-87 will work but when you get into the 80's you run into different line fittings, sure some of the guys here can tell you for sure which ones.
atheystruck@comcast.net 67 1/2 ton 4wd custom cab 72 1/2 ton 4wd super cheyenne 71 1/2 BB super cheyenne shortbed |
