Track Bars: Why not simply cut and weld?
Has anybody simply cut their track bar and re-welded it back together rather than spending a hundred bucks for an adjustable one?
A hundred here, a hundred there.... |
Intentionally Left Blank
Re: Track Bars: Why not simply cut and weld?
I have not, but along that same train of thought, why not cut it in the center slightly shorter that needed, thread both ends and make a threaded coupling out of some thick wall tubing. It could be like a tie rod end, just bigger. It would be completely adjustable and cost would be minimal if you had the tools to thread it with.--Jeff
1965 C-10 Short Fleet 468/TKO 5-Speed 2004 2500HD Crew 496/Ally Blacked Out (SOLD!!) 1997 Formula WS6 2004 Jeep Wrangler (Sold) 2013 Jeep Wrangler (Sold) 2017 Jeep Wrangler (Blacked Out on 35's) 2011 GMC D-Max Dually Denali 3500HD (Sold) 2015 GMC D-Max Dually Denali 3500HD (Sold) 2018 GMC D-Max Dually Denali 3500HD (Sold) 2020 D-Max Dually Denali on 33x12.50's 1979 GMC Short Bed Step-Side 4x4 350/350 Low Miles |
Junior Member
![]() Join Date: Mar 2007
Do it. cut it in half & use a piece of heavy wall tube over the joint. set it where you want it in the truck & weld it up solid.
frontstreetcycle on Instagram |
i had the same idea as you. I did do this .. although i havent had the truck together enough to actually drive it since ive done it... so i cant tell ya how well it worked hahah ... the problems of being in college and tryin to build a truck at the same time
Here's what I did with a link (for a tractor) that I got at Tractor Supply.Cost me 20 bucks and a little time!
![]() Join Date: Oct 2006
Looks goods,whats the Tractor Supply part number for the link?
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes. "Over, Around or through it... " |
![]() Join Date: Apr 2008
There is nothing special about the adjustable ones they are just made for many different types of vehicles, the important thing to remember about welding it is that if your skills are not up to par, you could really hurt yourself or others. If the bar is solid type then it needs to be beveled and a full pen weld is necessary not just surface welded, all the while making sure that the heat does not distort the bar.
Usually along with the adjustable track bar you get the brackets that makes it level.
I'd rather attempt something great and fail.. than try something ordinary and succeed. Norman Vincent Peale Project: Barn Raising http://67-72chevytrucks.com/vboard/s...d.php?t=414961 Project: 30 Be Low https://67-72chevytrucks.com/vboard/...d.php?t=830583 |
[QUOTE=slepysal;4293665]Looks goods,whats the Tractor Supply part number for the link?[I don't have the part number,I just saw it while walking around and a light bulb turned on
gets board easy.......
i used a peice of 1 inch square and plug welded it,
cut the center down and trim to desired length then weld up the whole thing loooks square now |
#10 | |
Enjoy your truck
I replaced the cut/welded one a couple of years ago with an adjudstable unit when I could afford it. Greg.
1 Corinthians 10:13 1963 Chevrolet 1/2 ton 2010 Camaro SS/RS 2014 Jeep Grand Cherokee 2016 Jeep Cherokee |
have used these for years on many oval track cars and yes they are very very strong. you can purchase them in any length from 4inches to 30inches in steel or aluminum for around 10.00 for the tube and 6.00bucks each for the heims in 5/8,1/2 or 3/4 inch sizes. just measure the overall length and subtract 3inches for the heims and that is the tube you need.you can even get the rubber bushed or urethane joints if need be for about 12.00 each try http://www.speedwaymotors.com/Swedge...im-Joints.html got most anything you need
Due to financial constraints, the light at the end of the tunnel will be shut off until further notice Last edited by bama63; 11-14-2010 at 01:22 AM. |
Master Procrastinator
I'm all for the do it yourself, and creativity of making your own products, for me though the $100 on a manufactured adjustable bar that mounts direct into factory spots, comes powdercoated, with poly bushings, and new grade 8 bolts, I'm way too lazy
![]() 20 Duramax tow pig 68 2wd short stepper project 77 2wd short fleet beater 52 short project |
#13 |
and a few others
I did my 63 when I lowered it also. No problems. It ain't pretty if you're going the show truck route though.
Bill ![]() BlueRidgeMuscleCars.com “The greatness of a nation and its moral progress can be judged by the way its animals are treated” Gandhi |
#14 |
Check The Champ, Demonstrator
![]() Join Date: Jun 2009
Buddy's 31 Chevy 5 window coupe, had a guy custom build him one, First time I was in the car it broke going around a corner. My bud told me I was to fat and banished me from the car. That hurts, I'm still in group over that one.
1963 Chevrolet Truck Literature LINK: https://picasaweb.google.com/113840717762774560215 YouTube Channel with 20+ Original Chevrolet Truck Salesmen, Mechanics & Service Department Training Slideshows. https://www.youtube.com/results?sear...otruk63&page=1 |
#15 |
this was mine on my 61
61 step/long bed SBW(SOLD) NEED A NEW PROJECT |
#16 |
This is the one I bought from brothers, a littel cheaper.. http://www.brotherstrucks.com/prodin...r=TRACKARM%2DL
`64 C10 vortec 350/350/373 posi `69 RS/SS 350/350/308 `37 Ford 406/350/324 traclock `68 Dart 370/904/323 suregrip |
#17 |
Thanks for ll the input guys! I guess my hundred dollar first post comment can be beat.
Here is one for $59 bucks! Early Classics P/N 912-6572PB Adjustable panhard bar kit '65-'72 C-10 w/Bushings http://www.earlyclassic.com/catalog....y=panhard+bars But I can weld it myself for free.... Adjustability though would be nice. Edit 11-23-2010: I made a solid model in CAD of the rear suspension on my '65 C10 shortbed 1/2 ton 2 wheel drive to see just how the rear suspension articulates as a result of being constrained by the track armand trailing arms. Image below is an aerial view with frame at ride height: ![]() Image below is the frame is at ride height (rear crossmembers removed to allow viewing of track bar) Note angle of track bar in the following photos ![]() Image below is the rear axle is hanging, being suspended by the coil springs. (Note: This moves the axle to the right a negligible amount < 1/8") ![]() Image below is fully bottomed out, frame is on the top of the rear axle tubes. (NOTE: This moves the axle to the left approx. 11/16" from the std. ride height position) ![]() Image below is fully articulated, at ride height on left side, bottomed out on right side. (Note: This moves the axle to the right a negligible amount < 1/16") ![]() Image below is fully articulated, at ride height on right side, bottomed out on left side. (Note: This moves the axle to the left approx. 1/2" from the std. ride height position) ![]() Pretty neat stuff don't ya think? Last edited by lakeroadster; 01-09-2011 at 08:06 PM. |
#18 |
![]() Join Date: Jul 2006
I don't see any problem just cutting the bar and putting a nice clean, deep bevel on either cut then welding it back together. There is some tensile and compressive force on that bar but not enough that I would be concerned about a fully penetrating weld breaking. Might try that now come to think of it since I want to add rear blocks for a total of 6" drop.
CPP has an adjustable one that's not expensive too: http://www.classicperform.com/Store/...k/6572DATB.htm
'20 Silverado Trail Boss ~ '17 Tahoe ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '71 Cheyenne swb ~ '55 Pontiac Safari ~'50 3100 bagged ~ '80 Wife ~ Late model kids
#19 |
For a super budget build I see no problem in cutting and welding it, if you have the right tools and skill. Trust me, I have cut and welded them before and then decided to lower the truck a little more so I put a bend in it to shorten it bit more (joe dirt style). But, by the time you spend chasing a couple of adjustable ends, cutting, welding, and rattle can it, your money ahead to buy a 100.00 adjustable bar that is powder coated and has new bushings at both ends. just my .02 Sean
#20 | |
60-66 Nut
![]() ![]() Join Date: Mar 2007
You can build your own adjustable panhard bar. You will just need a piece of the appropriate DOM tube, a couple threaded tube adapters (you can even go with left and right hand threads), and a couple rod ends. Although the reality is than you can likely buy one already made for the same cost as buying the parts. But considering that we all are into building our own trucks, it isn't always about the price, but the satisfaction of having done it ourselves.
Here's a couple sources for the tube adapters and rod ends.... http://www.ballisticfabrication.com/...pters_c_7.html http://artmorrison.com/homepage.html Quote:
#21 |
Who Me?
The one for my 65 was cut and welded like Rain Man's above.
![]() 1997 Tahoe LT 4D 2WD (DD) 2001 Blazer 4D 2WD 1961 Apache 10 (sold) 1965 C10 Stepper (sold) |
#22 |
#23 |
Pics of mine.
I actually boxed rear inside of pass trailing arm and welded tabs to make my track bar longer. Longer equals less rear movement left to right as rear suspension cycles. Hope this makes sence?
I LOVE BURNOUTS ![]() ![]() NO BOZO's |
#24 |
Who Me?
#25 |
Who Me?
I bought one this week. I will post pics this weekend of my bar swap.
