Old 11-13-2010, 07:47 PM   #1
crossy's son
Driveshaft help
Hey guys my Buddy has an 84 K10 Shortbed 4x4 with 700R4 Trans and 208 T-case.....The rear driveshaft is gone and the only part we recovered is the yoke that slides into the T-case.
I found a Driveshaft for sale, From an 82 Shortbed 4x4 (same truck) but it had an SM465 4 speed manual with 208 T-case.
The guy swears it's the same because the difference is made up with the Adapter on the back of the SM465...
Is the Driveshaft the same?
OR if someone has a 700R4 4x4 Shortbed can you PLEASE measure your driveshaft from Weld To weld?? We don't even have the shaft to measure off of....
Brandon
Mine- '91 GMC RCSB 2wd, 350tbi, 5 speed, 3.42 G80
-Dad/Me Projects/Toys
75 SWB Silverado Factory 454, Th400
87 SWB Silverado 305tbi, 700r4, 2.73's...17.4 @74mph
a couple dodge cummins trucks.
PLEASE DO NOT MESSAGE ME ABOUT FACTORY TACH DASHES, I AM NOT MY FATHER AND I KNOW VERY LITTLE ABOUT THEM. Thanks
crossy's son is offline   Reply With Quote
Old 11-13-2010, 08:41 PM   #2
f.monroe
f.monroe's Avatar
Re: Driveshaft help
Slide the yoke you have into the T-case and measure to the center of the yoke on the rear differential. Measure his from the center of the u-joint rollers and compare. That should give you a pretty good idea if it will work.
Frank
Born and proudly residing in a Red State !
f.monroe is offline   Reply With Quote
Old 11-13-2010, 10:21 PM   #3
crossy's son
Re: Driveshaft help
Got it... I found old measurements I wrote down when this happend before ......for some reason my buddy's truck spits out driveshafts.
The one on craigslist will work! 33" w to w
