Old 11-13-2010, 09:05 PM   #1
Spoof
Spoof's Avatar
Shifter detent function
I've acquired a rebuilt tilt column and I just installed the shifter arm. I tried running it though the gears on my work bench, imagining it linked to a transmission.
I functions correctly in that you have to pull the spring loaded arm towards you to allow a shift out of park but then it just glides through the rest of the movement.
I haven't shifted a GMC in 7 years, does the only indexing on the column shift from park to reverse?
Thanks guys.
71 GMC 1500 LWB
Spoof is offline   Reply With Quote
Old 11-13-2010, 09:24 PM   #2
rsavage
rsavage's Avatar
Re: Shifter detent function
The detents are in the transmission.
1961 C1 Corvette
1959 El Camino 350 TPI, 9" 4 w disc
69 Blazer K5 - sold July '20
2021 Durango RT 5.7
rsavage is offline   Reply With Quote
Old 11-13-2010, 09:31 PM   #3
nyncompute
nyncompute's Avatar
I had the same question when I went to a tilt. Seemed to not have that hard click- click like the fixed column. But it shifts with a detent type action , just not as pronounced.
1972 K-10 SWB Cheyenne
nyncompute is offline   Reply With Quote
Old 11-14-2010, 12:44 AM   #4
sjarrett71
sjarrett71's Avatar
What he said...
-Scott-
sjarrett71 is offline   Reply With Quote
Old 11-14-2010, 03:06 PM   #5
Spoof
Spoof's Avatar
To clarify, the shift column requires the shifter be pulled towards you to shift out of park, not the transmission. This is to prevent a accidental shift from park into reverse. I'm going to assume there is no further indexing in the shift column and it's ready for install.
Cheers
71 GMC 1500 LWB
Old 11-14-2010, 08:24 PM   #6
john
member #16
john's Avatar
the tilt does have a detent plate. Kind of hard to see detent notches in the pic. Its the plate with two screws.
john is offline   Reply With Quote
