Old 11-13-2010, 10:20 PM   #1
60apache
60apache's Avatar
5.3 swap what year
what year model should I get for a 5.3 swap?
60apache is offline   Reply With Quote
Old 11-14-2010, 12:42 AM   #2
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
Re: 5.3 swap what year
not sure it matters...with the 6.0's you want '01 up....so I'd say the same or newer?
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 11-14-2010, 01:34 PM   #3
usmcchevy
Has more rust than truck...
usmcchevy's Avatar
Unlike the 6.0 the 5.3 is good right from the start. Generally speaking horsepower ratings increase as you get newer.
99-02 if you cant a cable TB
03+ got DBW
The reason you want 01+ for the 6.0 is 00- came with cast iron heads and a longer rear crank snout which is used for 4l80e but cannot be used with the 4l60e.
http://en.wikipedia.org/wiki/GM_LS_engine
And here is a pretty good deal on a 06 5.3/4l60e not that far from you
http://www.performancetrucks.net/for...d.php?t=472218
1972 Custom/10 SWB, 4.8/4l80e
Build thread
LSx Swap FAQ index
usmcchevy is offline   Reply With Quote
Old 11-14-2010, 11:22 PM   #4
60apache
60apache's Avatar
so all 03+ is drive by wire? if I get 03+ what do I do for cable throttle?
Old 11-14-2010, 11:31 PM   #5
68GMCCustom
pretty sure you can just change it for a cable throttle and then make changes in PCM for it.
Kurt -
Old 11-14-2010, 11:47 PM   #6
Critter
Future TOTM Winner
Critter's Avatar
I might be mistaken, but I don't think the Vans got dbw until a year or so later. When I was engine hunting I ran across an 2004 6.0 from a 2500 van and it was still cable. I don't remember all the specifics, but maybe that info will be valuable to you at some point.
72 Chevy CST K5 HIGHLANDER BLAZER Getting a 6.0,NV4500,NP205,14BFF (Currently laying all over the place in little pieces)
72 Chevy swb step-side "LS" 6.0 Here's a build thread of sorts
2002 HD2500 Crew Cab, 8.1L Allison 4x4 Daily Driver
Check it out www.lsdyno.com
Critter is offline   Reply With Quote
Old 11-14-2010, 11:54 PM   #7
60apache
60apache's Avatar
well I am going to do 5.3 not 6.0
Old 11-15-2010, 12:08 AM   #8
Critter
Future TOTM Winner
Critter's Avatar
Vans had 5.3s as well. I was just trying to help out.
Old 11-15-2010, 12:12 AM   #9
60apache
60apache's Avatar
I got ya I will check it out
Old 11-15-2010, 02:49 PM   #10
usmcchevy
usmcchevy's Avatar
I'm learning the vans are different animal. They seem to be a year or more behind the trucks. I do know that 07+ vans are DBW. Good luck
Build thread
LSx Swap FAQ index
Old 11-15-2010, 05:41 PM   #11
LEEVON
Moderator
LEEVON's Avatar
Don't let the drive-by-wire deter you (03-up except vans). If you get one, get the pedal and cable too. If you want to convert to cable, you just need a cable intake and throttle body. They're cheap (like $75 cheap) and you could sell your drive-by-wire and make money.
Go for the most complete, lowest cost, lowest miles first and figure the rest out in my opinion.
'86 GMC C30 Crew ~ '86 C20 Crew ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '74K10 ~ '71 Cheyenne swb ~'50 3100 bagged ~ '80 Wife ~ Late model kids
LEEVON is offline   Reply With Quote
Old 11-17-2010, 09:05 PM   #12
60apache
60apache's Avatar
found a deal locally on a complete swap minus trans 20k miles 2002 5.3 for 700.00
Old 11-18-2010, 01:09 AM   #13
Critter
Future TOTM Winner
Critter's Avatar
That sounds like a great deal. However, if it were me I would ask for some proof that it is a 5.3 and not a 4.8. Not that a 4.8 is bad by any means, but it sounds like some people on this board have paid for one thing and got another. Can you see the truck it came out of or at least the airbox sticker that gives the engine size. Is it a private seller or a salvage yard?
