Old 11-13-2010, 11:09 PM   #1
chev-obsession
chev-obsession's Avatar
cpp brake master cylinder/ prop. valves?
Are the CPP master cyinders and proportioning vlalves any good? Im going with a manual setup
1965 c/10 swb
1969 c/10 lwb
chev-obsession is offline   Reply With Quote
Old 11-14-2010, 12:26 AM   #2
protrash64
Resistance is Futile
protrash64's Avatar
Re: cpp brake master cylinder/ prop. valves?
I'm sure they are fine, but if you want to save 10 bucks, use the POL set-up. Check it.......
http://www.performanceonline.com/60-...LVE-KIT-MCPVS/
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 11-14-2010, 02:10 AM   #3
Captainfab
60-66 Nut
You can also get a new or rebuilt master cylinder at your local auto parts supplier. The prop valve can be found at a wrecking yard or bought new. Which one depends on if you're running disc/drums or disc/disc.
Old 11-14-2010, 03:35 PM   #4
chev-obsession
i never thought of getting one at a parts store....
1965 c/10 swb
1969 c/10 lwb
Old 11-15-2010, 01:24 AM   #5
Captainfab
60-66 Nut
1971 to about 1974-5 were available with manual disc brakes. Then you'll just need a proportioning valve to suit. I wouldn't be afraid to use a prop valve out of a wrecking yard as long as it has had brake fuild in it recently. They don't go bad very often.
Old 03-14-2011, 08:49 PM   #6
S-31
I know im bringing up an old thread but im going to put manual disc brakes on my 62 pretty soon and i was wondering if, in addition to the proportioning valve, do i need to add a residual pressure valve in either the front or rear brake line? I had to do this to a 51 that i switched over to front discs years ago but i think it was because the master cylinder was under the floor on the frame rail. Just trying to cover all the bases before i get started.
S-31 is offline   Reply With Quote
Old 03-14-2011, 09:24 PM   #7
Rich 5150 69
Rich 5150 69's Avatar
Originally Posted by S-31 View Post
I I had to do this to a 51 that i switched over to front discs years ago but i think it was because the master cylinder was under the floor on the frame rail. Just trying to cover all the bases before i get started.
Yes you just answered your own question....good luck
`64 C10 vortec 350/350/373 posi
`69 RS/SS 350/350/308
`37 Ford 406/350/324 traclock
`68 Dart 370/904/323 suregrip
Rich 5150 69 is offline   Reply With Quote
