I have a oil leak i cant find. The oil is coming down the passanger side of the motor. It runs down the starter and blows all over the tranny and front driveline. I have checked dip stick,I checked and felt around the oil sending unit but i couldnt feel fresh oil. I also checked valve covers. i looked at the rear main to but i do see it coming from there. Could it be leaking between block and the heads?.it feels like oil back there i think. I found a piece of gasket sealer laying on the the bell housing.
#2 | |
Still plays with trucks
Re: 350 oil Leak
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577 69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been 69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc 68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E 79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars |
Re: 350 oil Leak
Intake gasket? The gasket sealer came out from the intake and the block i would guess. If you have a little mirror you could possibly see if that is it.
Name: Les ---------------------- Couple 80s Couple 70s One 68 ![]() |
