11-14-2010, 12:32 AM | #1 |
How hard is it to swap a rear end gear?
Next summer im swapping my truck from 8 lug to 5 lug, the rear end is out of a 71 cheyenne and im not sure what gear is in it now but i would like 3.08 or something lower like that if its not already and ive heard some people talk about how much of a pain it is and now im wondering myself. Any information or experiences on doing it would be great.
Thanks |
11-14-2010, 01:47 AM | #2 |
Re: How hard is it to swap a rear end gear?
it's easy to do it but to get it to last is a differant story. there's an art to getting everything set right. personally i'd just take it somewhere.
David |
11-14-2010, 02:30 AM | #3 |
Big Red - Now its a SWB!
I tried it once and it didn't last long....three days later my carrier was sheared into 3 pieces! I ended up getting another rear out of the junk yard that lasted the rest of the time that I had the truck.
68 3/4 ton (Project)-350 Small Block, .030 over, 10:1 comp, 3998993 heads, C3BX edelbrock intake, comp cams XE268, Holley 670 SA, long tube headers, dual flow 40's, E-fan, Alum rad, currently under the knife getting shortened and bagged build thread 41 3/4 ton (wife's)-flatbed, fully restored to original 01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's 02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's |
11-14-2010, 07:43 AM | #4 |
changing gears is very easy you take your rearend drop it off at a pros shop and pickup a day or so later
11-14-2010, 10:32 AM | #5 |
x2 let someone with some experence do it. the end result will be much better.
69 short fleet 350/350 "under construction" 70 short step 307/3 speed |
11-14-2010, 12:41 PM | #6 |
without the right tools it would be difficult. a company called ratech makes a tool thats pretty cheap to set pinion depth if you want to do it yourself. If you dont have a dial indicator and mag base, yoke holding tool, large torque wrench, and inch pound dial torque wrench I would think it would just be cheaper to have it done unless you plan to do this kind of job alot. best of luck!
11-14-2010, 02:02 PM | #7 |
I am debating the same thing right now. Did it with my dad a few times years ago and the rear's are still running strong. I am thinking I may just bite the bullet and pay for a pro to handle this one being I am sticking a 600hp motor in the truck would prefer not to detonate the rear end. LOL.
On that note anyone know of a good place in AZ to get a rear end done.
My build thread for Project TiC TaC/Jazzmin Oh Yeahhh Cheap work is never good and good work is never cheap. Lesson = learn to do it all the right way on your own. SqueegeeMan |
11-14-2010, 02:12 PM | #8 | |
Posted via Mobile Device |
11-14-2010, 02:17 PM | #9 |
Thanks I have never actually paid to have a rear end built but I am sure its not cheap I'll call them and get a price Frame goes in for powder coating in a bout 3 weeks so that would be the perfect time.
11-14-2010, 02:53 PM | #10 |
I bought new Eaton posi unit, new 3:73 richmond gears + install kit, new axle seals and new u-joints. It cost me around $800 for parts alone.
I was gonna attempt doing the install but the thought of ruining $800 in parts made me uneasy so ended up paying one of the best shops in B'ham to do it Hesco. It wasn't cheap (I am ashamed to say price ) by no means but I have peace of mind that its done right, Last edited by HOGDADDY; 11-14-2010 at 02:54 PM. |
11-14-2010, 06:02 PM | #11 |
Is it exspensive to have done? Whats the average cost to have it done?
11-14-2010, 06:45 PM | #12 |
Local place called Chandler speed shop told me I would be better off buying a whole new custom build rear end from Currie. They said after parts/time rebuilding my current one will only save me a few hundred over going with a custom high horse power set up. Which was around 2k
11-14-2010, 06:48 PM | #13 |
I would try to find another complete rear axle with the gear ratio you want. It may take awhile to find the right one, but there out there..... ALOT cheaper and easier to swap out! Just my advice!
11-14-2010, 06:50 PM | #14 |
for me its more about not breaking stuff. My motor will be in the 600 hp range. I have no idea what's currently in the rear end of my truck so that scares me.
11-14-2010, 07:00 PM | #15 |
next time i go out to the farm ill have to see what kind of rear end is it. The truck had a 350/350 combo im pretty sure
11-14-2010, 10:42 PM | #16 |
I tried it once, spent hours on it, got a perfect looking contact pattern, and it still made noise anyway. I haven't done another one since. Keep looking until you find a complete rear with the gears you want. It will be better and cheaper in the long run.
Ray
Live more responsibly. Eat lower on the food chain. Eat vegetarians. |
11-15-2010, 07:34 AM | #17 |
Six in a row makes it go...
I put 3.07 gears, Eaton cone-clutch posi, and new bearings in a 12-bolt. It took a lot of time and specialized tools.
There's really only four things to do, but they have to be right: 1. Set-up the pinion bearings (this rear uses a crush-sleeve, if you blow it you have to get another one and start over). 2. Set pinion depth (distance from centerline of ring gear to face of pinion). 3. Set backlash (shim carrier bearings until you get the right number). 4. Check patterns. If you don't have the right tools to use the carrier bearing diameters in the housing to establish a centerline and then measure from that centerline to the face of the installed pinion, you can't do the rest. This took me a good month or so of tweaking during the winter (I've been accused of being a bit paranoid). 10K miles so far with no problems.
67 C20 long step resto: http://67-72chevytrucks.com/vboard/s...d.php?t=342086 66 C10 long step build: http://67-72chevytrucks.com/vboard/s...=1#post3814790 CT to Alaska in a 67 C10: http://67-72chevytrucks.com/vboard/s...d.php?t=399224 “The height of sophistication is simplicity." - Clare Boothe Luce |
11-15-2010, 04:02 PM | #18 | |
Next, start setting the backlash using shims between the case and axle bearings. You'll need to grease the ring gear with a colored(I used yellow) grease to check pattern as you do this. A 12 bolt needs to be between .005 and .010 in of backlash as measured on a dial indicator. I didn't take a month doing mine... and that's not a criticism of anyone posting here. This was the 12th one I've done and practice makes it easier. Just be prepared to spend at least a day. That's how long number 12 took to get it to my liking and if you haven't done one before, take your time. In almost every car club there is someone who knows how to do this. If you can't find a club go to the vocational arts teacher at your local highschool or junior college. When you finally get the gears patterned correctly the pinion will leave "half moon" marks on the ring gear that are approximately centered in the teeth. The last photo is my 12 bolt after I was satisfied. It now has 5000mi and 14 passes at the drags behind my ZZ572 powered 67 stepside. That's 620 HP and it isn't broken yet! |
11-15-2010, 04:05 PM | #19 |
Good Info Fitz. I can see my future and it looks like a mechanic doing my gearing.
11-15-2010, 04:24 PM | #20 | |
Its a Truck Thing......
If you dont have the tools or knowledge leave the gears alone it is a hard lesson to learn. If you have a 3.73 rear and go to a 3.07/3.08 the carrier has to be changed if you rebuild it. Smitty
71 C10 283/3SPD Full Resto 71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599 70 C10 Suburban Former military GSA truck. 72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378 72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110 68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head 71 C30 Wrecker 71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck 68 GMC Long Stepside. They keep following me home 69 C30 Former Motor Home, Flat Bed time Last edited by 71meangreenc10; 11-15-2010 at 04:25 PM. |
11-16-2010, 01:16 AM | #21 |
Thanks guys for all your help, i sure hope it has the lower gears in it. This is a lesson i dont want to learn the exspensive way ive had enough of them already.
11-16-2010, 11:54 AM | #22 | |
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
