![]() Join Date: Jan 2009
what are these?
i have never seen these on a truck before? the came off bottoms of fenders, when i took the clip off my 70. i sandblasted them and figured i would get a little more info. thanks guys.
69 short fleet 350/350 "under construction" 70 short step 307/3 speed Last edited by redbaron69; 05-23-2011 at 08:06 PM. |
Re: what are these?
they attached to your front piller behind your rocker panel in which gives the pillar support when u go to bolt up your fender
1972 C-10...402/400..flowmaster 40 series 1967 Mustang 347 stroker/C-4 1966 Mustang 289/3-speed 2013 Mustang V6/6speed w/300 ponies I may be 23, but i sure do knows 67-72s are sexy! Its not MPG its smiles per gallon! build started 11/25/08 build thread: http://67-72chevytrucks.com/vboard/s....php?p=2993796 |
Re: what are these?
makes sense. Ive took a few trucks apart and this is the first set Ive run across.
69 short fleet 350/350 "under construction" 70 short step 307/3 speed |
![]() Join Date: May 2007
Re: what are these?
They should be spot welded to the pillar, as well as a couple of bolts.
Turp Mcspray New life for an old 2wd, farm blazer http://67-72chevytrucks.com/vboard/s...d.php?t=505987 My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299 |
