11-15-2010, 12:55 AM | #1 |
shaving bed to cab
I know it would put your bed on permantly but I was just wander if anyone has shaved the bed to the cab, or has ever seen one done?
11-15-2010, 01:16 AM | #2 |
Hollister Road Co.
Re: shaving bed to cab
The frame has to much flex to make that practical. The panels would buckle badly after a short time.
11-15-2010, 02:14 AM | #3 |
Big Red - Now its a SWB!
There is one on here that has been discussed lately. Here is a pic and the thread.
http://67-72chevytrucks.com/vboard/s...d.php?t=430586
68 3/4 ton (Project)-350 Small Block, .030 over, 10:1 comp, 3998993 heads, C3BX edelbrock intake, comp cams XE268, Holley 670 SA, long tube headers, dual flow 40's, E-fan, Alum rad, currently under the knife getting shortened and bagged build thread 41 3/4 ton (wife's)-flatbed, fully restored to original 01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's 02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's Last edited by Jacfourteen; 11-15-2010 at 02:15 AM. |
11-15-2010, 02:37 AM | #4 |
Here's a picture of one I saved. The cab is stretched too:
11-15-2010, 02:55 AM | #5 |
someday it will be done!
how bout shaving the cab all together?
'72 C-10 Proud owner of a million new and used pieces that used to be and will once again be(god willing) a testament to the term "they don't build em like that anymore. '80 LWB 2wd beater '67 GMC long fleet (cab donor) '66 long step (parked till it's turn comes around) '65 short step (parts truck that will donate it's bed and possibly frame to the '66) '06 Grand Prix wife's car (she hardly lets me touch it) my pics |
11-15-2010, 03:22 AM | #6 |
fully box the frame first that should stiffin the frame enuff to be able to do it
R.I.P. 1984 chevy c10 high performance 305 toteled 1987 mazda b2000 dads |
11-15-2010, 03:48 AM | #7 |
6>8 Plugless........
If this is true, then how do the Blazer's not buckle panels? They utilize the same frame.
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
11-15-2010, 07:52 AM | #8 |
blazer frame and truck frame are not the same
11-15-2010, 08:14 AM | #9 |
Blazers do buckle dont they? isn't that why they have the rocker boxes?
11-15-2010, 01:26 PM | #10 |
Seems that suburbans would suffer even worse from the frame flex with their extended length.
68 3/4 ton (Project)-350 Small Block, .030 over, 10:1 comp, 3998993 heads, C3BX edelbrock intake, comp cams XE268, Holley 670 SA, long tube headers, dual flow 40's, E-fan, Alum rad, currently under the knife getting shortened and bagged build thread 41 3/4 ton (wife's)-flatbed, fully restored to original 01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's 02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's |
11-15-2010, 04:28 PM | #11 |
Same frame except the ends where the rear bumper are. They are the same thickness and same height in the middle. The blazer has an extra body mount, where a pick up would have bolts holding the bed down. Now, there is a fifference in 2wd and 4wd. But every 2wd Blazer I have seen, had the exact same frame as a 2wd truck. Same with 4wd.
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. Last edited by Dieselwrencher; 11-15-2010 at 04:28 PM. |
11-15-2010, 04:29 PM | #12 |
I haven't seen any buckled from this. Mainly they rust out more than anything.
11-15-2010, 04:34 PM | #13 |
Insert Title Here
cut the roof of a truck and weld it on a blazer body
BOBBY _69 SWB_ 1000 pics of 67-72's>> http://s193.photobucket.com/albums/z...-72/?start=all << |
11-15-2010, 05:01 PM | #14 | |
Man of Mini-Talents
Steve Project - Ruth 66 Skylark Project - Lola 60 Biscayne Project - Iron Ox 54 GMC 100 Project - Darth 69 Camaro |
11-15-2010, 05:28 PM | #15 |
67cheby
heres a blazer on the board with a truck cab
11-15-2010, 06:01 PM | #16 | |
what you're saying is they're exactly the same except for the things that aint
11-15-2010, 06:09 PM | #17 |
Ok, you're right, I'm wrong. They aren't exactly the same, but they are the same structure which won't allow one to flex or twist more than the other enough to make it buckle like mentioned. I sure don't see pics or threads on here of suburbans and blazers with buckled body sides because of this.
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. Last edited by Dieselwrencher; 11-15-2010 at 06:11 PM. |
11-15-2010, 06:11 PM | #18 |
I've seen and even owned a couple of Fomoco Unibody pickups. One of F#rds "better ideas' from '61-63.
Unless you are hauling serious weights, binding and crumpling ain't gonna be an issue. While the unibody construction is visually appealing, it would only take one li'l ol' lady in a Walmart parking lot to ruin your day........ |
11-15-2010, 06:21 PM | #19 |
11-15-2010, 08:51 PM | #20 | |
Blazer frames are considerably shorter, which would stiffen it automatically. Suburbans have a perminent roof, which stiffens things even more....
The biggest issue I can see is that the cab has rubber isolators that allow the body to move around some , absorbing so road vibration. The bed is solidly bolted to the frame. That could pose a problem? Either way, that is not "shaving".....Moulding maybe? but "shaving" involves removing things that "stick up". Door handles, locks, gas fillers, antennas, turn signals, etc.
You can review the site's rules here. Quote:
Bad planning on your part does not necessarily constitute an instant emergency on my part.... The great thing about being a pessimist is that you are either pleasantly surprised or right. |
11-16-2010, 12:04 AM | #21 |
Not mine, just a picture I had saved. I believe it was for sale somewhere last year.
11-16-2010, 12:55 AM | #22 |
I totally agree. Remove the bed mounting bolts, add rubber bushings/mounts, and you would have no need to worry. It is now an ElCamino.
11-16-2010, 01:20 AM | #23 |
RAT1968 '68 Cab/'71 Parts
Really? Or did it originally have a roof that went waaaaay back............?????
Absolutely beautiful.
M17 Coarsegold, CA RAT's shiny now. But always a rat. |
11-16-2010, 10:43 AM | #24 |
Insert Title Here
no, the cab is stretched.....look how long the doors are
