help rear end gears
hi i have a 2wd lowered 1978 blazer with a 327 out of a 68 camaro, the motor is bored over 60 with a cam, it runs good except take off sucks. shoud i change my rear end gear? i was thinking 4:11's but i dont know
OutOfMyMind & I'llNeverKnowWhy
Re: help rear end gears
Tire size will make a big difference in what gearing is best. What size you got?
-Justin-Out of my mind and I'll never know why 1976 Chevrolet Silverado C10 350 4bbl / TH350 Big10 longbed 1986 Pontiac Firebird T-Top 5.0L TPI 700R4 WS6 1992 Pontiac Firebird T-Top 5.0L TBI 700R4 My cardomain page ![]() I don't like to save, it's more fun to spend!! |
![]() Join Date: Dec 2008
tranny ?
If you drive it daily, your best bet would probably be to stick a different (smaller) cam in it.
Just a guess without much info, but I'd imagine you have a huge cam in that motor, and it doesnt kick in till above 2,500+ RPM's. The cam probably calls for a stall converter and gears. Unless you have an overdrive transmission, you wont be running over 50MPH for any length of time on the highway if you put a 4:11 in the rear end. Last edited by Dru; 11-15-2010 at 04:36 AM. |
#7 | |
#8 | |
Happy to be here
![]() Join Date: Mar 2000
You mention you have "a 327 out of a 68 camaro, the motor is bored over 60 with a cam" but no mention of what the cam specs are. Knowing more details on what you have and what you are after will be very beneficial in getting good advice. In general, 3.08 gears were pretty common in the 73-80s trucks. They could be had with 3.42 or 3.73 gears as well. Based on what you have told us so far, I would not recommend a 4.10 gear set. If you currently have a 3.08 ratio, a 3.73 would be a good choice if low end torque is your primary goal. If your looking for better low end, and decent MPG the 3.42 is hard to beat.
Follow me on Facebook and Instagram @N2trux.com Articles- "Jake" the 84 to 74 crewcab "Elwood" the77_Remix 85 GMC Sierra "Scarlett" "Refining Sierra" Last edited by N2TRUX; 11-15-2010 at 12:07 PM. |
alright thinks
