Old 11-15-2010, 01:17 PM   #1
dnandez
dnandez's Avatar
4x4 Conversion to 2wd with a 454
Hello I am in the process of doing a 4x4 concersion to a 2wd. I started with a 71 blazer no options truck. Took out the 350 and put in a LS6 454. I removed the front clip from the 71. Now I have a 68 front clip that I plan on putting on tonight. This is my first time doing a project like this so any help would be apreciated. Here are some pics.
72' K5 Blazer
71' K5 2wd conversion project 454 ls7
71' C10 Cheyenne long box 66k original miles
dnandez is offline   Reply With Quote
Old 11-15-2010, 01:19 PM   #2
sandnuriz
sandnuriz's Avatar
Re: 4x4 Conversion to 2wd with a 454
Wow cant wait to see post up some pics and info as you go
57 Chevy shortbed,327,Muncie 4 speed,12 Bolt rear end(current project)
It's your ride build it the way you want !!!!!!!!!!
sandnuriz is offline   Reply With Quote
Old 11-15-2010, 05:02 PM   #3
bouncytruck
SKINNY TIRES RULE!
bouncytruck's Avatar
Keep the pictures coming! Did you modify the firewall or did you mount the engine in the forward (2wd) position?
bouncytruck 1972 K5
The Hauler 1994 K1500 Suburban
The Daily2010 Kia Soul
Wife's Ride2014 Fiat 500L
bouncytruck is offline   Reply With Quote
Old 11-15-2010, 06:43 PM   #4
dnandez
dnandez's Avatar
I mounted the engine in the 2wd position. I used a 77' front end. It was kind of a pain but it is done.
72' K5 Blazer
Old 11-15-2010, 08:15 PM   #5
tubbedII
needs more $$$
tubbedII's Avatar
Looks like fun! What did you do for the rear?
1970 2wd Blazer
tubbedII is offline   Reply With Quote
Old 11-15-2010, 09:33 PM   #6
Jacfourteen
Big Red - Now its a SWB!
Jacfourteen's Avatar
Nice looking project! Can't wait to see how it turns out.
68 3/4 ton (Project)-350 Small Block, .030 over, 10:1 comp, 3998993 heads, C3BX edelbrock intake, comp cams XE268, Holley 670 SA, long tube headers, dual flow 40's, E-fan, Alum rad, currently under the knife getting shortened and bagged build thread
41 3/4 ton (wife's)-flatbed, fully restored to original
01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's
02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's
Jacfourteen is offline   Reply With Quote
Old 11-16-2010, 02:39 PM   #7
dnandez
dnandez's Avatar
Right now it is still running leaf springs in the rear. I shaved the perches and welded on new ones to mount the axle on top of the springs droping the rear. Now I am getting a set of springs and drop a arms for the front to level it out.
72' K5 Blazer
Old 11-18-2010, 01:56 PM   #8
dnandez
dnandez's Avatar
I got rid of the 71' front clip now and I just picked up the 68 front clip to install. I will be installing the front clip this weekend. I will put some pics up then.
72' K5 Blazer
