11-15-2010, 05:15 PM | #1 |
new glass install
What is the best method for installing new glass in the side windows? I know LMC sales a new rubber to squeeze in the regulator channel, but I was thinking of gluing it in, with a window or glass adhesive. any thoughts?
11-15-2010, 06:09 PM | #2 |
Re: new glass install
I used a bead of silicone on my 69 15 years ago and it's still holding up just fine, I recently restored my 72 and used the same thing. I actually tried some of that glass setting tape and couldn't get it to work so I went ahead with the silicone. I cleaned out the channel and wiped down the bottom edge of the glass with alcohol, filled the channel with a bead of silicone and inserted the glass. After letting it sit overnight I trimmed of the excess silicone and installed the glass
Posted via Mobile Device Posted via Mobile Device |
11-15-2010, 06:23 PM | #3 |
The rubber setting tape lmc sells does not work very well, go to a glass shop and get some from them, it works as it should and is cheap.
67 blue step side- bb 68 gold and white swb cst anniversary 68 custom swb hot rod Ls swap 69 swb cst 6 cylinder/ overdrive 69 black/black cst bb swb 70 orange and white cst Canada built truck swb bb 71 black and white super swb bb 71 red and white super swb 72 green and white super swb 4x4 62 nova wagon 400 series Ls swapped 68 Camaro 327/4 speed- 1 owner, original paint 66 Volkswagen bettle 69 auto stick Volkswagen Beetle |
11-15-2010, 09:38 PM | #4 | |
11-15-2010, 09:38 PM | #5 |
This was just posted about 3 weeks ago and the thread has links to youtube of the install, try the search feature for windshield install ect..
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
11-15-2010, 11:17 PM | #6 |
I cant remember if I got it from LMC or Classic Parts, the stuff I got kept tearing and bunching up as I pressed the glass in the track, I tried it several times and finally just gave up and used the silicone. I have a stack of receipts from the suppliers I used last winter to restore my truck, I will look through and see if I can find out where I bought. I honestly cant say for sure if it was the tape or the way I was using it, I am usually very good at that kind of stuff but I did have a lot of trouble with the tape. I will take a look and check back in a bit.
Update, I found the order, I got it from LMC. Last edited by AirSpeed; 11-16-2010 at 12:05 AM. Reason: found order |
11-15-2010, 11:41 PM | #7 |
Eat, Sleep, Drive a Chevy
[QUOTE=AirSpeed;4296328]I used a bead of silicone on my 69 15 years ago and it's still holding up just fine, I recently restored my 72 and used the same thing. I actually tried some of that glass setting tape and couldn't get it to work so I went ahead with the silicone. I cleaned out the channel and wiped down the bottom edge of the glass with alcohol, filled the channel with a bead of silicone and inserted the glass. After letting it sit overnight I trimmed of the excess silicone and installed the glass
QUOTE] I have used silicone many times and never had any issues. Just clean the channel as stated above and let it dry!
Trey Silence may be Golden, but Duct Tape is Silver! 72 Short Step 57 "big window" short step |
11-16-2010, 10:23 AM | #8 |
Got big-block?
I just went through this installing the 1-piece window glass in my '72 K25. The window setting tape from Brothers and LMC does not work correctly. I spent 3 hours...that's right, 3 hours...trying to install the passenger side glass into the sash using the tape. I tried heating it with a heat gun...tried using a silicone lubricant...tried beating it with a rubber hammer. Finally, I was able to get it seated about 3/4s of the way into the channel and called it good. I was so pissed off I called it a day and went home to watch the Horns get destroyed by OSU...not a good day.
Sunday morning I tackled the drivers side. Ran a bead of black urethane in the sash channel...screw that tape...dropped the glass in...took 5 minutes! Let it dry all day...trimmed off the excess...perfect! Here's some pics:
'68 CST SWB factory 396/T400 buddy buckets, a/c, ps, pb '72 Corvette convertible 454/4spd/ac, ps, pb '73 GMC Sierra Grande short wide 454/T400 ps, pb, ac '77 K5 Blazer black on red, 350/T350/NP205 ps, pb, ac all original '78 GMC Sierra Classic short wide 454/T400 ps, pb, ac '72 GMC Sprint SP454. 1 of 38 built. '73 GMC Sprint SP454. 1 of 71 built. '75 GMC Sprint SP454. 1 of 25 built. SOLD! '72 GMC K25 4x4 468/4L80e/NP205 build thread http://67-72chevytrucks.com/vboard/s...23#post4324423 SOLD!'55 Chevy gasser 496/4spd build thread http://67-72chevytrucks.com/vboard/s...96#post4324396 |
11-16-2010, 10:29 AM | #9 | |
