Radiator/Shroud Question
'71 C10. Did the stock fan shroud physically mount to the radiator or some other place on the front of the truck? I have an aftermarket aluminum radiator right now and no fan shroud. The engine overheats if it just sits and idles for a while I assume due to the fact that there's no fan shroud to direct the air through the radiator. As long as I am moving forward it stays plenty cool. I am trying to decide whether I should replace the radiator with an OEM type ($200) and stock shroud or first try to get a stock shroud to mount with the current radiator. Any information or advice would be appreciated.
Re: Radiator/Shroud Question
The shroud bolts to the top radiator hold downs and the bottom clips to the lower part of the radiator support.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC |
So the shroud doesn't connect to the radiator itself at all? If not I'll probably try the cheaper route and get a stock shroud from LMC and see if I can get it to bolt on.......
![]() Join Date: Apr 2007
If your using the stock type top radiator clamps you should be in good shape. Pics attached of the 4 and 3 core versions. Sharpie
Thanks guys. I hope the shroud solves my overheating problem when not driving.......
Junior Member
If you don't have a shroud or the fan is not in the right place in the shroud you will have an over heating problem when not moving with the stock fan.
'67 Chevy C-20 short stepper - build complete, 454/SM-465. '75 C-30 Single Cab DRW-350 small block/NP-435. '77 GMC-6500 Dump Truck, 427 Tall Deck. '92 GMC K-3500 Duallie, 454/4L80E. |
