fan shroud mounting on factory radiator
Hey guys how does the reproduction fan shrouds from lmc , classic etc hook up to a factory radiator? I was going to order one but after looking at my radiator i only have the bolt holes where the radiator bolts to the front of the truck, i don't see the side mounts like in some of the pics on the other threads.
ie: http://67-72chevytrucks.com/vboard/s...ght=fan+shroud thx Last edited by badriand; 11-15-2010 at 10:14 PM. |
Re: fan shroud mounting on factory radiator
i ordered mine from brothers but i was missin those side mounts too.. i had mine made out of a street sign that i had a hot rod shop use there shear to cut out two rectangles and use there break to bend them both , in the "L" shape,i took measure ments off my cousins truck,,got them home drilled some holes and bolted shroud right on!!! guy only charged me 20 bucks and cut and bent them in less then 10 mins..just a thought...
I just replaced my radiator two days ago and the new radiator was made by someone who just looked at the dimensions and never actually installed one because its got some metal frame where the rubber gromets go. I had to take out the half inch rubber pieces and replace them with some thin hose I cut up and even then the brackets didn't line up enough. just a hair off though, I just ziptied it. my truck aint no show truck :P
thx guys.... Did it help a lot on the temp?
Couldn't tell you, I was running without water before and its too cold to tell
Yup. Used to overheat all the time. Now I tow in 100+ weather and it's never over 210. Fan shroud, heavy duty fan clutch and 19" steel fan. Works great!
Chris '63 k15 long step Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205 ![]() 52" front and 63" rear spring swap D44 / 14bff - disc axles Milemarker 9K and 10.5K hydraulic winches 63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29 |
| Bookmarks |
