03-03-2003, 11:29 PM | #1 |
senior member
Msd ??'s
I have a 307 everything is stock and i was wondering what MSD box setup would work the best also do i need new distributor ?
69 GMC bagged |
03-03-2003, 11:36 PM | #2 |
Used to have a truck
Ther msd 5 would work OK for a bone stock motor . For a motor with some oats I'd go with the MSD6 . The 6A is nice for hi revving motors that NEED a rev limiter but since hydraulic cams sort of act as their own rev limiter I'd say its not really necessary to have one on a hydraulic cam motor. For a solid lifter motor you dont want revving over 7G they are nice to have. Ive used all of the above and think the MSD 6 is the best bang for the buck in a street motor.
Nothing like forgetting to hook up the coil wire and then noticing the spark is jumping 3 inches to the firewall! MSD's are the SH!T! Oh yeah... One of the good things about MSD boxes is that since you only use the distributors points as a trigger you dont really run anywhere near the current through them that you did originally . Recurve the stock distributor for a better advance curve and install some stiff point springs like Accel or mallory sell and you can rev as hi as you like up to 7 grand using the points type distributor without ever wearing the points or the condenser out.
No truck :-( Last edited by mikep; 03-03-2003 at 11:42 PM. |
03-03-2003, 11:38 PM | #3 |
senior member
so even with everything stock i could use the MSD6? and my old distributor would work? i just dont want to spend a bunch of money and wreck something thanks MIKEP
69 GMC bagged |
03-03-2003, 11:43 PM | #4 |
I just editted a little bit so read above.
No truck :-( |
03-03-2003, 11:51 PM | #5 |
PROJECT 7DEUCE
Alway's pack a set of point's and condenser i have had a box fail and it suck's to be stranded!!!!!
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
