Old 11-16-2010, 11:01 AM   #1
KIC
1960 GMC Burb
KIC's Avatar
03 Tahoe LT Auto Ride leak
Hi guys,
Have an 03 Tahoe LT with the airbag/shock auto ride system. found two leaks coming from the thick rubber that covers part of the top of the shock. Had to pull the fuse to keep the air pump from going constantly.
If the rubber is leaking, does that mean a seal in the air shock is leaking?
Or is that heavy rubber part of the air shock/bag system part of the air holding system and just needs to be replaced? ?
Can they be rebuilt ? Or just replaced ? and I presume either is $$$$$.
Thanks for any info you gurus might have.
1960 GMC Suburban
1/2 ton V-6
2nd generation original owner
60 Burb Build thread: http://67-72chevytrucks.com/vboard/s...=1960+Suburban
60 to 66 Burbs only Thread: http://67-72chevytrucks.com/vboard/s...ighlight=burbs
2003 Tahoe LT
KIC is offline   Reply With Quote
Old 11-16-2010, 04:48 PM   #2
JohnC
JohnC's Avatar
Re: 03 Tahoe LT Auto Ride leak
I can't help you much on the solution to the problem. I did a search on Google for Tahoe Autoride problems, and found a write up on a couple of different sites. The solution is expensive, but some of the writeups helped cut down on the cost quite a bit.
JohnC is offline   Reply With Quote
