Old 11-16-2010, 02:55 PM   #1
Robert8096
Robert8096's Avatar
Rear spring bushings
What is the best way to remove the bushings from the rear springs and shackles on a 1/2 ton shorty?
Robert8096 is offline   Reply With Quote
Old 11-16-2010, 08:29 PM   #2
85gmcguy
Plays with trucks
85gmcguy's Avatar
Re: Rear spring bushings
I've never done it myself, but from what I hear/read an oxy-acetylene torch seems to be the tool of choice. Burn/melt/hammer and punch. sounds like a good time to me!
Gary
My Dad's Old Truck
1985
85gmcguy is offline   Reply With Quote
Old 11-17-2010, 12:42 AM   #3
1LowToy
I'd check with a specialty spring shop or supplier. My wife was a CRAZZZED Postal Worker and she had her own RH drive Jeep. A spring had broken on it and the local supplier had new springs in stock for a couple of C-notes. Otherwise I say a press and the right drift.
1LowToy is offline   Reply With Quote
Old 11-17-2010, 11:46 PM   #4
rblcori7
rblcori7's Avatar
When i had to replace mine i soaked them in some gas and then lit them on fire about 10 minutes later all that was left was the metal sleeve laying there....
84 Short bed 350: Hooker headers, flow master 40 series, edelbrock Intake manifold, Holly street avenger carb, 4 inch skyjacker suspension lift, 33x12.5 Toyo Open Country Mud Terrains, 3.73 gears
2011 Silverado LTZ
rblcori7 is offline   Reply With Quote
Old 11-18-2010, 09:31 AM   #5
Robert8096
Robert8096's Avatar
Seems like fire is the way to go but I am a little sheepish about heating the spring ends. I have a 25 ton press so I may soak them in penetrating oil and try the press, if that does not work then I will fire off the hot wrench. Had a bad experience with lighting up gas so I think I will pass on that option.
Thanks for the replies.
Old 11-18-2010, 11:38 AM   #6
Gordonr1973
Home Built '87
Gordonr1973's Avatar
When I replaced my bushings in my '98 I did not have a press at the time....so I used a power drill and drilled out as much rubber material in each bushing as I could get to (this is a long process and it stinks of burnt rubber) and when I got a little movement there I used a sledge hammer and socket to beat them out.
If you have a press you might be able to do it quicker that way.
I've ordered a master set of Energy Suspension bushings for my '87 and the set should arrive on Friday --- I'm going to do my bushings next week on it so if someone has a better idea (as I can't light them on fire in my backyard in the city) please let us both know!
Thanks!!
Gordon
1998 White Chev ext cab 2WD (Summer Project) http://67-72chevytrucks.com/vboard/s...d.php?t=408424
1987 Chev Silverado SWB (Winter Project Rebuild) http://67-72chevytrucks.com/vboard/s...d.php?t=424833
Truck Club http://67-72chevytrucks.com/vboard/s...d.php?t=466969
Gordonr1973 is offline   Reply With Quote
Old 11-18-2010, 11:54 AM   #7
Robert8096
Robert8096's Avatar
Thanks!!
Whats the part number of the bushings and who did you order them from ?
Robert
Old 11-18-2010, 12:43 PM   #8
Gordonr1973
Home Built '87
I got them through a local dealer who bought two different sets for me as the catalogue isn't clear on measurements....once they come in I'll give you the part number of the set that fit the truck.
Robert
Gordon
Old 11-18-2010, 01:21 PM   #9
Robert8096
Robert8096's Avatar
Old 11-20-2010, 03:16 PM   #10
Gordonr1973
Home Built '87
Thanks!!
I now recant my last post after spending 2 hours just getting one bushing apart....I am going to take all of my parts with bushings that need to be replaced and tonite I'm going to soak them in deisel fuel and tomorrow light them on fire at my dad's farm to burn them out. I'm tired of wasting time on chicken sh!t stuff like this!!
Gordon
Old 11-20-2010, 05:45 PM   #11
rblcori7
rblcori7's Avatar
I feel your pain man... that is exactly what i did i sat there with a a hammer and a vise and any other tool i could think of out of my tool box for 3 hours and still couldnt get them out so i said F it and got out the fuel lol
best of luck man
2011 Silverado LTZ
Old 11-20-2010, 08:02 PM   #12
menace121978
menace121978's Avatar
cool thread! i spent a good part of the day hammering away on mine last summer. i got 1 side done and said the heck with it and took them down to the local napa/machine shop and got drilled for $10 a bushing... well worth it though
"Dennis the Menace"
1978 Silverado (2wd, 1/2 ton, short bed)complete nut & bolt frame off restomod LQ9/4L80E
MY LS SWAP/FRAME OFF BUILD BOOK
2006 TBSS way too much to list
menace121978 is offline   Reply With Quote
Old 11-21-2010, 10:25 PM   #13
Gordonr1973
Home Built '87
Here's what I did today....good news is they came out after only about 4 or 5 minutes in the firs so the metal wasn't too overheated....and everything is going back to the sandblaster tomorrow to get cleaned off!
Gordon
Old 11-28-2010, 07:32 PM   #14
Robert8096
Robert8096's Avatar
FWIW. The 25 ton press made short work removing the bushings from the springs. I had to do a two step removal process on the shackle bushings, removed the steel sleeve and then the rubber portion. It took me more time to go dig the press out of my storage container than removing the bushings. Total time with press setup was about an hour.
Old 12-03-2010, 02:29 PM   #15
Gordonr1973
Home Built '87
The Energy part number that fit for me was: 3.2106R (R is for red bushings that I used)
Gordon
Old 12-03-2010, 02:35 PM   #16
Gordonr1973
Home Built '87
Energy Suspension 3.2106 R (red)
Gordon
Old 12-03-2010, 02:40 PM   #17
Robert8096
Robert8096's Avatar
Thanks for the info,I ordered those same bushings (but black) and they fit the springs just fine but an 1/8 inch too large for the shackles. It may be that somtime in the trucks life they were replaced with aftermarket units. I took the shackles and bushings to a friend and he is going to try to mill down the bushings to fit. Let me know if you run across this problem.
Old 12-03-2010, 08:57 PM   #18
Gordonr1973
Home Built '87
Since my shackles were new and had new rubber bushings, I left those as-is.
Gordon
Old 12-03-2010, 09:10 PM   #19
SeanPaintsFlames
SeanPaintsFlames's Avatar
Since neither I nor my neighbors are big fans of a big rubber smoke out, I used a different method that I've not seen mentioned. I had a hole saw that was just the right size to fit in between the inner and outer sleeves, and it only took a few minutes to get each of them out. The sleeves were the biggest pain. Having to air-chisel the edges in and slowly fold them over to the inside until they just gave way and popped out- that took about 20 minutes each.
My 68 cougar restomod build:HERE
SeanPaintsFlames is offline   Reply With Quote
Old 12-18-2010, 04:35 PM   #20
lilpoindexter
lilpoindexter's Avatar
I took a socket of just under the size of the metal shell, and beat them out with a small mallet. I didn't struggle too bad, although i was pretty tired when I was done.
I put the new ones in the freezer over night, and they went in with no drama.
lilpoindexter is offline   Reply With Quote
Old 12-18-2010, 06:34 PM   #21
mooseknuckles
mooseknuckles's Avatar
burn em out with a torch.
mooseknuckles is offline   Reply With Quote
