Old 11-16-2010, 04:41 PM   #1
red71c10
The Red Menace
red71c10's Avatar
Bed Swap Pointers?
I'm getting ready to replace the Swiss cheese bed on my truck with a much more solid one. Any advice on getting the old bolts loose? Someone said there are some welds to get through too, where would those be and how hard are they to get through? Any other things I need to be aware of? Thanks!
1971 Custom 10 - 350/350TH - Pwr steering, gauges, Chrome front bumper, Chrome hubcaps, Door edge guards, HD rear springs (current)
1968 C-20 Custom Camper - 350/350TH (orig 327), Pwr steering & brakes, gauges w/tach (former)
1968 C-20 - 307/3sp column (Dad's when I was a kid)
"Driving is like coloring. Things get messy if you can't stay inside the lines."
red71c10 is offline   Reply With Quote
Old 11-16-2010, 05:28 PM   #2
cdowns
cdowns's Avatar
Re: Bed Swap Pointers?
if it's just a matter of swapping beds// there are but a few bolts holding bed onto the frame i normally just grind them down and lift the old bed off and place the new bed in place and use new bolts
Old 11-16-2010, 05:59 PM   #3
bguild
bguild's Avatar
Yes its just bolts.. You are better off buying new bolts. I just bought some from classic parts for like 10-20 bucks for the set. Just gring them off or cut the bolts.
Project "Edna Marie"http://www.67-72chevytrucks.com/vboa...74#post5998074
Toys:
2014 Dodge Ram
1967 SHORTBED
bguild is offline   Reply With Quote
Old 11-16-2010, 08:17 PM   #4
Jacfourteen
Big Red - Now its a SWB!
Jacfourteen's Avatar
I used a cutting torch to cut the old bolts, then put in a new floor with new bolts.
68 3/4 ton (Project)-350 Small Block, .030 over, 10:1 comp, 3998993 heads, C3BX edelbrock intake, comp cams XE268, Holley 670 SA, long tube headers, dual flow 40's, E-fan, Alum rad, currently under the knife getting shortened and bagged build thread
41 3/4 ton (wife's)-flatbed, fully restored to original
01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's
02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's
Jacfourteen is offline   Reply With Quote
Old 11-16-2010, 09:41 PM   #5
red71c10
The Red Menace
red71c10's Avatar
Thanks! I bought a new bolt kit for the swap. It'll happen this Saturday. Glad to be finally getting rid of all that rust!
