275R55-17 on all 4's
Has anyone used this wheel/tire set up?
Front wheels 17x8 w/ 4"BS with 275/55-17 Rear wheels 17x9.5 w/ 5" /BS with 275/55-17 Most people use 255/(55 or 50)-17 for the fronts, but I am having a really hard time finding matching sets with the 255/275 combination. The overall width of the 255/275 tires has only a 3/4" difference 275 (10.82") and 255 (10.04"). I figure that with the offset of the 8" wheel I can compensate for the wider tire at the front. I can get a good price locally for the 275/55-17 on Toyo ST ii, and before I buy them I will like to know if there will be a fitment issue at the front. Any ideas or suggestions? |
Re: 275R55-17 on all 4's
The only tire you will find with a matching 255 is in a Pirelli Scorpion Assimetrico.
You can run a 275 all around with little to no clearance issues. If you read the other thread about 17x8 wheels, member JCA1972 is running 275/60/17's on all corners with no issues. The only problem you may have will be in how much your truck is lowered.
i run these on all four corners with no issue stock truck height
I just had to replace the tires on my 2001 Silverado and I run the 255/50 r17 front on a
8" wide wheel and 275/50 r17 on 9.5" wide wheel in the rear. The only matching front and rear set I could find was the Nitto 450. I have gone through a couple of sets on my truck and have been averaging 45 to 50 thousand miles on them. They seem to be a fairly decent tire that isn't too expensive. |
Thanks for the input. I guess I can run 275/55 or 275/60 in al corners with no problems. Thanks guys.
Chevy Truck Addict
![]() Join Date: Aug 2006
I put a set of Falken tires on my 1990. The S/T Z01 comes in a 255/50 and 275/50 which I was running on 17x8's front and back. I was really happy with them. If you can still find them, I have Yokahama Advan S/T's on my '70 and they are exceptional. I am running 255/50's up front and 275/55's on 17x8's and 17x9.5" rims.
. 1970 Chev C/10 SWB, 355 SBC, 700R4, 3.73 Posi, Air Ride (Click to view Build Thread) (SOLD) 1978 Chevy C/10 SWB 1970 Pontiac Lemans . |
Tags |
corners i mean! |
