Old 11-16-2010, 06:26 PM   #1
kenm78
Broken Down
kenm78's Avatar
Left Door Vent Window
Well I done did it!! I opened my little triagle vent window on my drivers door and the bottom stud/pivot broke so now it's just flapping by the outside hinge. How hard are these darn things to replace. I looked on LMC and they are a pretty penny $349.95 OUTRAGIOUS!!!! Any ideas to my delima?
kenm78
1982 Chevy 4X4
Project truck
“It’s better to keep your mouth shut and let people wonder about your ignorance, than open your mouth and reveal all doubt”
kenm78 is offline   Reply With Quote
Old 11-16-2010, 08:30 PM   #2
PRattenbury
Re: Left Door Vent Window
I'd go to the boneyard and get one. They're pretty easy to take out.
PRattenbury is offline   Reply With Quote
Old 11-16-2010, 09:49 PM   #3
motornut
78K & 79C Jimmys
motornut's Avatar
and they fit a wide year range,i just put 89 suburban vents into my 78 jimmy,and the later years have locks on them
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Old 11-16-2010, 11:59 PM   #4
kenm78
Broken Down
kenm78's Avatar
They look like a PINA to swap out. What needs to be done to change them.
kenm78
1982 Chevy 4X4
Project truck
Old 11-17-2010, 12:15 AM   #5
motornut
78K & 79C Jimmys
motornut's Avatar
for me the hardest part was the screws in the door frames(rusty).had to tap them with a hammer while turning them(seen with door open) yellow dots on door frame
and one screw on top of door-up red arrow
window crank clip
4 screws across the bottom- yellow dots
2 screws in handle area- yellow dots
1 screw side edge-yellow dot
red dots are bolts to remove under panel
and there will be a small crew (to remove)holding the inside to the outside just under the vent window......jimmy and wiggle it out
John
Old 11-17-2010, 12:49 PM   #6
TDS-MN
And the front channel for the door glass is integral with the vent window assembly, so you'll be removing and replacing the operable window glass as well. Unless there's some way to leave it connected to the mechanism, and simply line the vent window and track, with the door glass? Haven't had to do this yet, but have the vent window assembly and a bare door sitting on my workbench, awaiting some time to work on it.
Pretty sure that the 'hinge' point of the vent window, is integral with the frame. I too was shocked by the price in the LMC and various catalogs, and scored a used vent window assembly from the salvage yard. Seemed like the easiest way to solve the problem, but it has turned intoa pretty involved repair.
Good luck with yours!
TomS.
'98 S-10 Blazer 4dr 4wd - 4.3, AT, stock
'85 K-10 w/ 305, 700r4, np208, and RUST!
SOLD Dec 2014
TDS-MN is offline   Reply With Quote
