Old 11-16-2010, 07:31 PM   #1
my69camaro1
Young One
M1006 CUCV ? CrewCab 2wd to 4wd Conversion
Well I've had a 1981 GMC 1ton 454ci crew 2wd dually for several months now, I couldn't decided if I wanted to drop it down or 4x4 it.
Think I've decided to go for a 4x4 srw conversion.. Love the look but any decent K30 around here goes for big bucks so I'll build my own (or at least try).
Parts truck is a 1984 Chevy M1008 1.25ton that ended up having a blown head gasket and mild rust that isn't worth repairing to me (GL gamble).
I plan to keep the 454 in the crew for a while but would like to do a cummins swap. Swapping the m1008 dog house and bed onto the crew, the th400 trans and np208 case, then obviously both axles and spring mounts.
Will find a small lift to fit my 37in radial TSLs that have been sitting in the polebarn forever. Gonna put them on 2pc hummer rims. I then plan to paint the crew in the 3 color mil spec paint to match all our other military toys.
69 R/S Camaro
79 K5
86 M1008
11 P71 Vic
12 Ram 3500
18 Ram 2500
my69camaro1 is offline   Reply With Quote
Old 11-16-2010, 07:51 PM   #2
Savage
Savage's Avatar
Re: M1006 CUCV ? CrewCab 2wd to 4wd Conversion
this is going to be SICK! exactly what i have always wanted. can't wait
United States Marine Corps
1986 USMC CUCV M1008 (daily driver) / 1984 Chevy K10 RCLB
Savage is offline   Reply With Quote
Old 11-16-2010, 09:58 PM   #3
48cj2a
48cj2a's Avatar
Look forward to your conversion. I have a USAF Civy K3500 Crew Cab so if you need pictures of anything let me know. The engine is out too.
If you could come up with the front hubs for the front axle you could leave the rear end a dually and make a M1028A4
Are your battery cables still unbutchered from the firewall terminal block to the batteries in the CUCV and if so would you be interested in selling them?
03 Suburban Z71 Z71
98 GMC Yukon SLT 4x4 Yukon
86 M1009 CUCV Project Milverado
48 Willys CJ2A 48CJ2A
48cj2a is offline   Reply With Quote
Old 11-17-2010, 03:33 PM   #4
my69camaro1
Young One
I'll check the batt cables tonight... I know I cut the one going to the starter cause I rounded a bolt off.
I had today off so I spent a little time yanking the motor out. She drove into the pole barn just fine but smoked constantly from drivers pipe and oil in radiator. Ended up just throwing it in the back of a deuce for scrap. Kept alts and starter.
69 R/S Camaro
79 K5
86 M1008
11 P71 Vic
12 Ram 3500
18 Ram 2500
Old 11-17-2010, 03:45 PM   #5
LiveAnimals
LiveAnimals's Avatar
Very much subscribed to this build
Kameron
YESTERDAY IS HISTORY - TOMORROW IS A MYSTERY
I'm a Middle ClASS HOLE
07.5 Dodge 3500 CTD -- Daily
73 C10 Factory BB SWB 2WD
LiveAnimals is offline   Reply With Quote
Old 11-17-2010, 04:12 PM   #6
GmtGmt
Conversion Truck Addicted
GmtGmt's Avatar
your scrapping the 6.2?
i might want a few parts from it if you do
Thomas
Tonight mine pulled a few cars out of snowbanks, and is sitting in my driveway, icicles on the grille, wheels just white cakes of snow, buried up to the lug nuts in powder, straps and chains wrapped around the bumpers, the outline of the wipers clear in 4 inches of snow on the windshield... A tired warrior of the 1980s in a world of low profile tires, front wheel drive, and plastic bumpers, where people stay in their houses until snowplows move the offending substance from their paths, too helpless to travel without AAA and chains and salt, clearing their windows with longhandled brushes while gently stepping around in the snow trying to stay nice and dry.
GmtGmt is offline   Reply With Quote
Old 11-17-2010, 04:39 PM   #7
Greenlee
Greenlee's Avatar
I started a similar project using a 2wd 87' body, and M1008 frame and axles. I think the easiest way to do it is to swap everything over to the M1008 frame, which is very heavy duty by the way. The down side would be if you are worried about having different VIN's on the frame and cab. In Texas I don't think that is a big deal. With the crewcab, I guess there isn't an easy way of doing.
Greenlee is offline   Reply With Quote
Old 11-17-2010, 07:22 PM   #8
my69camaro1
Young One
Let me know what you need, I think all the glow plugs are shot and the IP leaks. I don't know anyone who wants a 6.2 in need of work and I don't want it so it'll go to the junk man.
Old 11-17-2010, 07:28 PM   #9
my69camaro1
Young One
Yeah the frame on the m1008 looks to be in real nice shape but the crew cab part has me over a barrel. I thought about cutting frames and swapping entire front ends but not sure I like the idea. I've got grinders and torches so I'm not to worried about rivets.
Old 11-18-2010, 10:18 AM   #10
Stitch
Location: Where I come from, it's cornbread and chicken...
The m1008 has a one ton frame and all crewcabs have 1 ton frames. The cucv front frame clip I have is exactly the same height and thickness as my crewcab frame
Stitch is offline   Reply With Quote
Old 11-18-2010, 10:43 AM   #11
48cj2a
48cj2a's Avatar
Stitch is there any difference in 3/4 and 1 ton crew cabs frames?
2wd and 4wd frames?
03 Suburban Z71 Z71
Old 11-18-2010, 12:45 PM   #12
GmtGmt
GmtGmt's Avatar
Injectors, IP, lines, sensors, and a few odds and ends
can you get me some pics of it?
Thomas
Old 11-19-2010, 08:45 PM   #13
my69camaro1
Young One
I'll go take some pics of it tomorrow afternoon.
69 R/S Camaro
79 K5
86 M1008
11 P71 Vic
12 Ram 3500
18 Ram 2500
Old 12-15-2010, 12:43 PM   #14
my69camaro1
Young One
Haven't forgot about this thread... Only been able to work on it a few days this past month. We've got about 2ft of snow and ~15 degree temps so that doesnt motivate me much either. I've got the front suspension off, so I'll probably drag the other truck in and start on the swap. I want to get the front end done before starting the back half. And I'm not looking forward to drilling and torching off all those rivets in the back.
Old 12-15-2010, 04:56 PM   #15
Mattman2010
Mattman2010's Avatar
Take lots of pictures as I am doing this as well. I was going to go with the single rear wheels, but the duallys are just badass. As for removing the rivets from the rear, I removed them all to mount my 14b and after I was done I decided I wanted to go back to dually. They are not fun to cut off!
1980 K10 - 6.2L Diesel/SM465/NP205
Build Thread
1984 K30 CC Dually - "The Tank"
12V Cummins/Nv4500/Np205/D60/D70HD 4" lift & 37's
Build Thread
1960 C-60 Dump Truck
Make it road worthy!
Thread
Mattman2010 is offline   Reply With Quote
Old 12-15-2010, 05:27 PM   #16
48cj2a
48cj2a's Avatar
I feel your pain, I got my motor swapped Thanksgiving weekend and got it turning over last Friday during our scorture day but 15 degree temps is a killer especially when I'm doing it in the driveway.
03 Suburban Z71 Z71
Old 12-19-2010, 12:06 PM   #17
pvkj454
I did the M1008 to 2wd crew frame splice on my build:
http://67-72chevytrucks.com/vboard/s...d.php?t=404146
1986 Chevy crew dually 4x4, 1995 6BT Cummins, 5x12 injectors, 3k gov kit, modified AFC, hybrid Super 40/HX35 turbo, boxed frame, 19.5 wheels.
pvkj454 is offline   Reply With Quote
Old 12-20-2010, 02:04 PM   #18
Devillusion
Devillusion's Avatar
subscribed
1967 K30 4x4/12v Cummins/getrag/D60/D70/355s
1967 GMC suburban 4x4/LS swap 5.3/4500/205/10 bolt/14 bolt full floater
1963 C10 reg cab long box
1970 Chevelle
1968 Biscayne 2dr post
"...there is no excuse for what I am about to do, but dangit....it's gonna be fun!"
Devillusion is offline   Reply With Quote
