Old 11-17-2010, 02:44 AM   #1
Yellow76
Yellow76's Avatar
How big of lift is this truck?
How big of lift do you guys think this truck is? Those are 37s boggers
Yellow76 is offline   Reply With Quote
Old 11-17-2010, 08:05 AM   #2
Re: How big of lift is this truck?
I can only guess.I'd say 8-10",leaning towards 8".
Old 11-17-2010, 01:26 PM   #3
Plunkett
I'd say 8" as well. My 6" lift with 35's has the same clearance as that truck.
Plunkett is offline   Reply With Quote
Old 11-17-2010, 10:25 PM   #4
Yellow76
Yellow76's Avatar
Alright well the guy i bought it from thought it was a 6 but i agree with you guys it looks a little bigger i think a 8 the front drive line cant go any higher if that makes a difference
Old 11-17-2010, 11:51 PM   #5
Plunkett
Here is a picture of my truck with a 6" and 35's. It's hard to say from the picture but it could be a 6".
Old 11-18-2010, 05:59 PM   #6
scottsdaleowner75
Thats a 6 inch lift. Anymore and the drivlines MUST be extended. 6 is the absolute max and event hen you cant wheel it hard without some driveline issues.
scottsdaleowner75 is offline   Reply With Quote
Old 11-18-2010, 10:50 PM   #7
Davidmichael
Davidmichael's Avatar
My truck with a 6" and 36's do not have that much room from tire to fender. I would say it's an 8" lift, but the drive shaft thing is throwing me off a bit.
86 Suburban 2WD = rolled it and totaled it
83 LWB STD Cab 4x4 = went to the scrapper. Was my baby.
84 Suburban 2WD = stripped it/ scrapped it
81 8 foot bed made into a trailer
86 Suburban going to be made into a trailer
91 Suburban 4x4 = that's my baby
00 S10 Xtreme STD Cab
01 S10 ZR2
Davidmichael is offline   Reply With Quote
Old 11-18-2010, 11:38 PM   #8
SeventyOne
Why has no one asked him what size tire he is running? This will tell all.
SeventyOne is offline   Reply With Quote
Old 11-19-2010, 08:10 AM   #9
First post:
Old 11-19-2010, 04:09 PM   #10
SeventyOne
First post:
Old 11-20-2010, 02:08 PM   #11
Yellow76
Yellow76's Avatar
Well i bought the truck with everything on it already so i could be wrong on the stock drive line but it cant have anymore lift do to the driveline
Old 11-20-2010, 10:02 PM   #12
dutchmanz
Knuckle Buster, Instructor
dutchmanz's Avatar
Could be a 6" with some body lift.
dutchmanz is offline   Reply With Quote
Old 11-20-2010, 10:49 PM   #13
Davidmichael
it does not look like there's any body lift.
01 S10 ZR2
Old 11-20-2010, 11:52 PM   #14
Critter
Future TOTM Winner
Critter's Avatar
Easiest and most accurate thing to do is get a measurement from the top of the axle tube up to the frame rail right above it, front or back. Then get some of these guys with the same truck and a known amount of lift to do the same and compare the numbers. Big block/small block/diesel/1500/2500 should all be kept "apples-to-apples" as well. Tire size doesn't play a factor doing it this way.
72 Chevy CST K5 HIGHLANDER BLAZER Getting a 6.0,NV4500,NP205,14BFF (Currently laying all over the place in little pieces)
72 Chevy swb step-side "LS" 6.0 Here's a build thread of sorts
2002 HD2500 Crew Cab, 8.1L Allison 4x4 Daily Driver
Check it out www.lsdyno.com
Critter is offline   Reply With Quote
