Old 11-17-2010, 05:23 PM   #1
breeh
Recovering 67-72 Addict
breeh's Avatar
D44 to D60
Finally took out the D44 and installed the D60 in my '68. Wow, much larger axle! I like it!
68 Short Fleet 4x4; 427; BTO Level 3 700R4; NP205; Dana 60 front and rear; 4" lift with 35's; Disc brakes; AGR variable ratio steering; factory bucket seats; factory tach and tilt.
"Friends call me cruzer cuz I like fast cars and fast women"
breeh is offline   Reply With Quote
Old 11-17-2010, 06:17 PM   #2
Yukon Jack
Post Whore
Yukon Jack's Avatar
Re: D44 to D60
Congrats on the install. I put one in mine this spring - I sure dig the disk brakes too!
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 11-17-2010, 06:32 PM   #3
breeh
breeh's Avatar
Re: D44 to D60
I was thinking about you while putting this in and wondering if you got yours installed. I haven't driven it yet as I am waiting on brake lines. Have you noticed any affect on your turning radius?
Old 11-20-2010, 06:28 AM   #4
mcmlxix
Collector of Projects
mcmlxix's Avatar
Re: D44 to D60
Whats the averag price of a D60? I was told about one local, 4.10 gears and new hubs.... condition unknown....
Rich
1972 K5 Blazer CST Click HERE
Old 11-20-2010, 01:27 PM   #5
breeh
breeh's Avatar
Re: D44 to D60
I purchased mine for $800 and was told that it was a runner. OF course, that wasn't the case and I ended up rebuilding the entire thing. I probably have $1600 in it now.
Old 11-21-2010, 01:59 PM   #6
Yukon Jack
Post Whore
Yukon Jack's Avatar
Re: D44 to D60
I went from a closed knuckle Dana 44 so the change in turning radius is dramatically better!
Old 11-21-2010, 03:20 PM   #7
'63GENIII
'63GENIII's Avatar
Re: D44 to D60
Hey Breeh not to get off topic, but I noticed in your sig that you have the BTO 700r4 behind a 427. How is it holding up so far? Do you tow with it? I'm looking at a 4l80e but like the 1st gear of the 700. Just curious. The 60 looks great BTW! It's on my Xmas list but I'll probably get a tie or something. Good work!
Chris
'63 k15 long step
Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205
52" front and 63" rear spring swap
D44 / 14bff - disc axles
Milemarker 9K and 10.5K hydraulic winches
63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread
NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build
L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29
'63GENIII is offline   Reply With Quote
Old 11-22-2010, 02:46 AM   #8
breeh
breeh's Avatar
Re: D44 to D60
I have been running that 700r4 for 8 years now without a single issue. When I put it in there were some guys on here that were against them but it has been a reliable transmission. I get better mileage now with the big block and overdrive then I did with the original 6 banger 4 speed combo that it came with. However, I don't tow anything with it.
I get ties for Christmas too. I make my own list for what I really want
Old 11-22-2010, 02:47 AM   #9
breeh
breeh's Avatar
Re: D44 to D60
As an added note now that I have been able to drive it, the turning radius is markedly improved over the D44 and the brakes? Wow!
Old 11-23-2010, 10:40 AM   #10
OLDCHEV4X4
OLDCHEV4X4's Avatar
Re: D44 to D60
Does the ring and pinion match, or do you gotta do a swap.
72 k/10 short wideside
72 k/5 Blazer
72 K/5 Blazer - obstacle course racer
72 custom/10 8' bed
70 K/5 Blazer
67 C-30 GMC Flat bed
86 GMC K2500 Plow Truck
85 GMC K3500
84 M1008
85 M1008
77 G30 Motor Home
72 Sears 12hp Tractor
Glenmoore, Pennsylvania
OLDCHEV4X4 is offline   Reply With Quote
Old 11-23-2010, 04:51 PM   #11
breeh
breeh's Avatar
Re: D44 to D60
Not sure that I understand your question. It had the correct ratio to match my rearend already. Same as the D44.
Old 11-23-2010, 07:14 PM   #12
OLDCHEV4X4
OLDCHEV4X4's Avatar
Re: D44 to D60
I was asking if the front D60 ring and pinion matched the rear, or do you have to change the front ring and pinion to match the rear.
But you already answered my question....., they match. What ratio is it?
72 k/5 Blazer
72 custom/10 8' bed
70 K/5 Blazer
85 GMC K3500
84 M1008
85 M1008
77 G30 Motor Home
Old 11-24-2010, 12:02 AM   #13
'63GENIII
'63GENIII's Avatar
Re: D44 to D60
Looks great, congrats. It is a great feeling to know that you will not be picking broken axle pieces out of the housing anytime soon. Dana 60 = peace of mind! Good idea on the xmas list too!
Chris
'63 k15 long step
