11-17-2010, 06:45 PM | #1 |
suggestions on 16" 4x4 rims
I want to go with 16" 6 lug rims on my 72 4x4 blazer,I know the late chevy wheels wont work due to the center hole size,is there any factory 16" wheel that i could look for or what aftermarket wheel is the best deal and would bolt on.16" tires seem to be cheaper and easier to come by.Right now i have 33x12.50 15 goodyear wrangler mtr's but there shot.
11-17-2010, 07:45 PM | #2 |
Re: suggestions on 16" 4x4 rims
Don't know about stock wheels that will work but plenty of 16" wheels can be had pretty cheap that will bolt up and look great - just depends on your style.
I used summitracing.com to widdle down the selection based on the search function they have where you can add in filters like: 16" wheel, 8" wide, 6x5.5, 3.5" BS, center bore size, etc,. Just keep filtering till you find the wheels for you. |
11-18-2010, 07:26 AM | #3 |
The lip on those 16" wheels are differnt, some pros & cons to using them.
Easy to break the bead but don't go wheelin' and air down to far. |
11-18-2010, 07:48 PM | #4 | |
I think you're thinking of the 16.5" rims with the crappy bead. Nothing wrong with the 16"s.
71 Blazer / GMPP ZZ383 / MPFI / 700R4 / 4-Wheel Disk / Ground-up frame off almost completed resto-mod |
11-19-2010, 08:16 AM | #5 | |
dohh Yeah, I was. Last edited by vtblazer; 11-19-2010 at 08:17 AM. |
11-20-2010, 04:18 PM | #6 |
urban fourwheelin
I'd really like a set of factory 4x4 steel 6 lug rims. I'm thinking about having a set made. I have a perfect set of hubcaps I want to run.
1972 K5 Blazer with Cummins 4BT, NV4500 swap in the parts gathering stage. |
