Old 11-17-2010, 06:53 PM   #1
TheSeeker
Question Quadrajet Question
Hey everyone the baseplate on my stock qjet is warped and leaking. Does anyone make a replacement or do I need a new carb? And If I had to get a new carb I need a new intake too correct? Can anyone give me a part number or model of a bolt on deal that will give me comparable performance to my rochester? Thanks. If it matters the truck is bone stock 350/350 with 520,000 miles.
TheSeeker is offline   Reply With Quote
Old 11-17-2010, 07:43 PM   #2
llowlife
Re: Quadrajet Question
How about just finding a different baseplate?
In the beginning of a change, the patriot is a scarce man, brave hated and scorned. When his cause succeeds however, the timid join him , for then it costs nothing to be a patriot.
I am a revolutionary...so my son can be a farmer...so his son can be a poet. If there must be trouble, let it be in my day, so my child may have peace...
72 short step w/ 388 /4l80e/ and 3.08 gears.
llowlife is offline   Reply With Quote
Old 11-17-2010, 07:47 PM   #3
TheSeeker
If its something that is easliy swapped I would definatly like to keep this carb. Its kind of cool to have it all there as it was in 70'. I bought a nice rebuild kit online today but didnt see a baseplate. Would it be something I can find and put in realitivy simply? Thanks, sorry if they seem like basic questions.
Old 11-17-2010, 08:54 PM   #4
nyncompute
nyncompute's Avatar
There are un-warping tools for the q-jets that are available..also if you have a quad rebuilt, some offer that service as well. Like everything, I'm sure that option is not cheap.
1972 K-10 SWB Cheyenne
nyncompute is offline   Reply With Quote
Old 11-17-2010, 08:59 PM   #5
geezer#99
geezer#99's Avatar
Are you sure it's not the fuel bowl wells that are leaking. They're dead centre underneath and prone to leak. JB Weld fixes it.
I don't think I've ever seen or heard of a warped baseplate.
Old 11-17-2010, 10:31 PM   #6
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
On the bottom of the float bowl, there are two plugs beneath the bowls. Those plugs will leak. Guaranteed to leak, in fact.
NAPA has, or had, a kit that included two plugs with o-rings that seal against leaks. Also, carb kits include a couple of sponge-like pieces that fit into the bottom of the bowl and hold those plugs in-place to prevent leakage.
You should be able to find a good steel straight-edge and know if the throttle plate is warped, or not.
Member Nr. 2770
Old 11-17-2010, 11:15 PM   #7
Cisco714
NAPA has/had a kit but good luck getting it. I recently had to order one my self and it was a challenge to say the least. I'm in the west though so that may or may not matter. It sure wont hurt to try. Good Luck
Cisco714 is offline   Reply With Quote
Old 11-18-2010, 06:21 AM   #8
shiner2001
shiner2001's Avatar
Not trying to hijack, but I am also running an original Q-jet and was curious if you had any info or part numbers for the kit you ordered...
Derek
72 Chevy Cheyenne Super LWB 454 SS LS6
90 GMC Suburban V2500 350
64 Chevy El Camino 357
73 Jeep Wagoneer 360
78 Jeep Cherokee 360
79 Scout II 345
88 Jeep Wrangler 4.2L
91 Jeep Wrangler 4.3L
98 Lincoln Mark VIII 4.6L
01 GMC Yukon 5.3L
"If it's not broken, fix it 'till it is!"
shiner2001 is offline   Reply With Quote
Old 11-18-2010, 08:19 AM   #9
Cisco714
Let me dig through my notes as soon as I get home. I'm sure I have it somewhere.
Old 11-18-2010, 10:56 AM   #10
Cisco714
http://www.napaonline.com/Search/Res...76&Ntk=Keyword
Here is the link and according to the web site they have 1 of each in the store closest to me. But of course that may change depending on where you're at.
Derek
Old 11-18-2010, 11:00 AM   #11
DT1
DT1's Avatar
Google "Cliff Ruggles" He's the Rochester man and can set you up with a very high quality rebuild kit. He also wrote the book on rebuilding and modifying Rochester carburetors for just about any application.
DT1 is offline   Reply With Quote
Old 11-18-2010, 02:01 PM   #12
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Modifying Q-Jets was the thing to do, "back in the day". The SS 396 Chevelles from '66, came with that carb. A good carb person could modify the way the secondaries opened (among other things) and someone else would be hard-pressed to know it had been done. It sure made those cars run waaaaaay better. Of course, there were other GM cars with that carburetor, but I also have to tell you that when they were new....there was some skepticism in the minds of those who didn't have one. It's the same with anything that is new and un-tried. But, we monitor and adjust. It's all good. I like my Q-Jet.
Member Nr. 2770
Old 11-18-2010, 02:41 PM   #13
68gmsee
Active Member
68gmsee's Avatar
I agree... Make absolutely sure the base is warped before going to the trouble of replacing it. It's not difficult to check out with a square after you remove the carb.
My recommendation is to read as much as you can about the quadrajet and check places on the net that give instruction on dismantiling and testing. Even Youtube has information on them.
Here's a site you can check out. Scroll down and you will see the wells that geezer is talking about.
http://www.carcraft.com/howto/57178/index.html
68gmsee is offline   Reply With Quote
Old 11-18-2010, 07:43 PM   #14
geezer#99
geezer#99's Avatar
Here's another link for you.
http://www.florida4x4.com/tech/quadrajet/
Old 11-19-2010, 05:31 AM   #15
shiner2001
shiner2001's Avatar
Derek
The link redirects me to the general front page of their site...do you have the part number so I can search for it that way? Many thanks!!
Derek
79 Scout II 345
01 GMC Yukon 5.3L
Old 11-19-2010, 05:36 AM   #16
shiner2001
shiner2001's Avatar
Missed this one before I replied...I got some reading to do!
Derek
79 Scout II 345
01 GMC Yukon 5.3L
Old 11-19-2010, 09:45 PM   #17
Cisco714
Carburetor Kit
Product Line: Echlin Fuel System
Comments: w/ Rochester Carburetor;w/ Carburetor Type: R-4;w/ Carburetor # 17054923, 7029214, 7040206, 7040509, 7041206, 7041208, 7041209, 7041211
Per Car Qty.: 1
Compare part # CRB 25784
Carburetor Kit
Comments: w/ Rochester Carburetor;w/ Carburetor Type: R-4;w/ Carburetor # 7029223, 7029224, 7040208, 7040511
Per Car Qty.: 1
Compare part #CRB 25782
Old 11-20-2010, 04:58 AM   #18
shiner2001
shiner2001's Avatar
Carburetor Kit
Per Car Qty.: 1
Carburetor Kit
Per Car Qty.: 1
Thanks!
Derek
79 Scout II 345
01 GMC Yukon 5.3L
Old 11-22-2010, 03:06 AM   #19
slikside
slikside's Avatar
In the process of rebuilding my q-jet now. I bought Cliff Ruggles book, got his rebuild (HP) kit and utilized his baseplate reconditioning/bushing install service. The carb is nearly ready for reinstall and tuuning. But to your question of warped base plate...I dont know if mine was warped or not, but I do know that Cliff reconditions both sides of it on a belt sander after removing both the primary and secondary throttle shafts and plates with assosiated linkages. I thought the service well worth the $45.
He also sells a plug/epoxy kit for $20. It requires drilling out and tapping these well plugs, and then screwing in new plugs with the epoxy. I bought this kit b4 I bought his book where he says to test them b4 replacing. Just take a soap and water mix, put it on the well plugs, and introduce compressed air into the cavities. Any leaks show up as a stream of bubbles. Turned out mine did not leak. I have a factory replacement Rochester 17054927 q-jet on my '72 C-10. It was manufactured in Dec. 1976, and he says it is quite rare to find leaking plugs in q-jets manufactured after 1975; very common on early q-jets.
Air horns, on the other hand are almost always warped, I know mine is. He reconditions these in the same way after removing the brass tubes protrruding from the bottom of it. But he also says that q-jets can tolerate quite a bit of warping in this area and still function well. I'm just using the thicker of the two gaskets provided.
While I'm not up and running yet, so far I'm pleased with the book, Cliff's service, and progress thus far. I just wish I had more time!!!!
www.cliffshighperformance.com
slikside is offline   Reply With Quote
