Dana 60 leaf spring pad spacing
I have a Dana 60 from a 69 3/4ton 2wd for sale. I guy contacted me about it and wanted to know the spacing for the spring pads, so I measured it at 42-3/8" from center bolt to center bolt.
He said his 3/4ton 4x4 is at 40". Is this correct, or did one of us mis-measure? |
Re: Dana 60 leaf spring pad spacing
I think 4x4 leafs are 2.5 inch... 1/4 inch wider than the 2x4 leafs, but the mounts and pads should be the same width center to center.. I think he is measuring between the pads which makes sense because he is about 2.5 inches shorter than you...roughly half a 2.5 inch leaf on each side...
1971 C-20 350/350 |
Yes, some of the earlier axles were spaced wider at 42.5". My 70 GMC C2500 has the Dana 60HD spaced at 42.5", also. There are some other threads on here talking about this.
1972 K20 Suburban 5.7/700r4/NP205 Dana 44/H052 Sold ![]() 1972 C10 5.3L/4L60E 12bolt 5Lug - Sold ![]() 1971 K5 Blazer 6.0L LQ9 4L60E NP205 Dana 44/H052!!! ![]() 1970 K3500 1ton CrewCab 8.1L/Allison1000/NP205 Dana 60/14B!!!! - Sold ![]() ![]() ![]() 1988 V30 CCLB 7.4L/TH400/NP205/Dana 60/Dana 70!!! (Sold) ![]() 2003 K2500HD 8.1/Allison1000/NP263 ![]() |
The Longhorns are 40" center to center,same as a cab/chassis....Im not sure on the 4x4's tho... crazyAl
http://community.webshots.com/user/hotrodhorn |
Member #1049
Both 4X4's and longhorns (3/4 ton & 1 ton) had straight frames and use the same spacing at
40" .. 2WD frames are "bowed out" at the rear end and do measure at 42.5" Last edited by Livrat; 11-19-2010 at 12:56 AM. |
6>8 Plugless........
![]() Join Date: Sep 2007
I just measured my Longhorn today, and from outside of perch to outside of perch it was 42 1/4". Just yo give you an idea.
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
Big Red - Now its a SWB!
It's been awhile since I measured my 3/4 dana 60 leaf rear but I remember it being around 42" so it must be the 42 and 3/8" mentioned above. Oh yeah it's a 2wd.
68 3/4 ton ![]() ![]() 41 3/4 ton ![]() 01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's 02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's |
#8 | |
Ray
Live more responsibly. Eat lower on the food chain. Eat vegetarians. |
I ran into this exact problem today. I took a Dana 60 from a '70 3/4 ton 2wd and put under the rear of a '72 1/2 ton 4wd chassis, and I can't bolt it up right now because the spring pads on the Dana 60 are spaced farther apart than the springs are on the 4wd...
Zach 1970 Chevrolet Custom Camper K20 1971 GMC Super K2500, 12V/NV4500 swap in progress 1971 Chevrolet Custom C10 1972 Chevrolet Custom Deluxe C20, 5.3/4L60E 1972 Oldsmobile Cutlass Supreme, 455/TH400, 3.73 posi 2004 GMC Sierra 2500HD, LB7/Allison, CCSB 2005 GMC Sierra 1500, 5.3/4L60E, CCSB |
#10 | |
Ok so i'm not alone, My truck is also 40" ctr to ctr.... The odd ball, maybe thats gonna be the new name, Odd Ball Swamp Rat LOL!
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
