Brake setup problems help please
Alright guys here's the deal I have a 1970 c10 2wd I'm converting it to disc brakes in the front I picked up a set of 71 spindles and rotors I got the rotors turned and new calipers ect... Now I got a proportioning valve from classic and my truck had drums and only 1 line In the front the proportioning valve has 2 in the front and the front line isn't the same size as the font lines and the rear also isn't the same... What did you guys do... I think my Option is to make new lines... What proportioning valve did y'all use?
Posted via Mobile Device |
67-72 parts collector,…
![]() Join Date: Nov 2002
Re: Brake setup problems help please
I plugged the top front port of the prop. valve.
I used "inverted flare" adapters to convert the line sizes.
I got my M/C and prop. valve from POL (www.PerformanceOnLine.com)
Sweet thanks alot
