Old 11-17-2010, 09:54 PM   #1
60apache
60apache's Avatar
5.3 swap with a/c
I have a sanden compressor now with my vintage a/c and going to do a 5.3 swap. should I use the factory compressor or use the sanden? also should I use one of the relocation brackets and move it to the pass side top? and help or advice appreciated.
60apache is offline   Reply With Quote
Old 11-18-2010, 12:04 AM   #2
Ackattack
Ackattack's Avatar
Re: 5.3 swap with a/c
I used a factory compressor in the stock (lsx that is) location.
Ackattack is offline   Reply With Quote
Old 11-18-2010, 12:11 AM   #3
LEEVON
Moderator
LEEVON's Avatar
Well a stock compressor probably isn't cheap so if you're looking for brackets that fit the sanden go here, don't spend a mint on billet-y bling.
www.kwikperf.com
nice guys too, they just do this on the side for fun.
'86 GMC C30 Crew ~ '86 C20 Crew ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '74K10 ~ '71 Cheyenne swb ~'50 3100 bagged ~ '80 Wife ~ Late model kids
LEEVON is offline   Reply With Quote
Old 11-18-2010, 12:43 AM   #4
60apache
60apache's Avatar
www.kwikperf.com
yes thats the brackets I was looking at. heres the deal I have a sanden compressor now also the 5.3 swap I am buying also has a factory compressor so do I use the factory? or do I use the sanden and buy the brackets? I want to know the best way. also if I use the sanden I have I will have to change the clutch to a serpentine.
Old 11-18-2010, 12:44 AM   #5
60apache
60apache's Avatar
when you say stock do you mean stock ls1 or truck location
Old 11-18-2010, 11:43 AM   #6
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
I used the 4.8 compressor with some Doc's Bloks and I still had to clearance the frame rail. I would do the Sanden and the Kwik Performance brackets, looks good and performs very well with the sanden compressor. Sell the LS compressor and it will pay for about half of the cost of the Kwik Performance mount. You can get a ribbed clutch from VA for about $100.00. Doing it this way will not be the cheapest. however If I had to do it all over again, it is the way I would go for looks and useability.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 11-18-2010, 08:50 PM   #7
Ackattack
Ackattack's Avatar
ls1
Old 11-18-2010, 10:29 PM   #8
60apache
60apache's Avatar
thank you that helps a lot
