03-04-2003, 02:56 AM | #1 |
Polyeurethane or polygraphite?
which should i go with for the suspension rebuild on my truck? and why should i choose one over the other?
BTW, i'll be dropping it 5/7. |
03-04-2003, 03:03 AM | #2 |
i think i'm gonna use the poly graphite ones, i think its the pst kit. they are supoosed to not squeak or somthin. if i get mine before you get yours i'll let you know how it is
'51 F100, backhalf with a narrowed 9 and coil overs, 18.5" mickeys, monte front clip, +400" sbc in the works '05 1500 Crew Cab RIP '84 swb 5/7 drop, solid cammed 408 w/ fully ported dart heads, th350 w/ 10 inch hughes, 12 bolt w/ 3.73 richmonds and a locker '80 swb 4x4 in progress: 7" lift, 350 th350/np205, d44 and 1.5" ORD tie rod, 14BFF w/discs , armored diff covers, 40" MTR's |
03-04-2003, 06:26 AM | #3 |
You get what you pay for
By all means, go with polygraphite. You can't grease control arm bushings after they are on and it will start squeaking after awhile with regular urethane. Only thing I don't like about polygraphite is they only come in black.
Mike 1985 Chevy C-10 |
03-04-2003, 01:24 PM | #4 |
Gentleman Jim Driver
I had polygraphite bushings on a vehicle once and they squeaked like a mother. I don't know if I believe they are self lubricating. They might be better than plain polyurethane but I don't see how. I've talked to others with that had the same results. If you don't want squeaking, use rubber.
Joe '75 GMC Gentleman Jim '84 Chev C10 Short Wide - Super duper plain (manual steering, manual brakes, no dome light, no cig lighter) '85 Chev C10 Short Wide - Super plain Vortec 4.8 4L60E trans also: '81 K30, '83 C30 Crew Dually, '84 M1028 CUCV, '85 M1009 CUCV, another '85 C10 SWB, '89 R3500 Flatbed |
03-04-2003, 01:44 PM | #5 |
www.73-87chevytrucks.com
I have used both and was happy with either one. The one of choice currently is PST.
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
03-10-2003, 02:37 AM | #6 |
i think im gonna go against the recomendations. i'll be using the Energy Suspension bushings, in blue no less. my truck is going to be black, with grey and blue accents, i think the blue bushings will add a nice touch of detail to the suspension/chassis.
