![]() Join Date: Dec 2009
van tilt wiring adapter?
Where can I find a adapter to fit a van tilt to facorty wiring harness in our 67
C10 truck? The van connector is kinda half moon shaped and factory is flat type. Any help would be great. Brandon |
67cheby
![]() Join Date: Sep 2008
Re: van tilt wiring adapter?
you can get them from IDIDIT
68 stepside http://67-72chevytrucks.com/vboard/s...0&goto=newpost |
its all about the +6 inches
dealer, less than 12 bucks
![]() Join Date: Aug 2009
I found adapters in some 1971 and 1972 trucks... it was kinda random in the trucks i found them in. I bought a after market adapter from lmc and it didnt fit right so i pulled it back out then when i was looking for other parts i found the adapter in a automatic truck with a none tilt column. so if you just check around you should be able to find one. I am not allowed to sell on here but if you post a i want to buy add i bet a few members on here probably have some stashed away.... I will also check to see if i have any left.
And just what do you tell the deal you want/looking for?
I have only one of these left... like i said the one i bought from lmc (page 95 part number 36-0599) I tried to modify and still no worky....
CCP has them for $15
Spike ![]()
Have you bought any from them? Do they fit properly? that would be the test....
#10 | |
Spike ![]()
