11-18-2010, 04:54 PM | #1 |
Dual Exhaust question
I currently have true dual exhaust on my 69 GMC 350 and I'm planning on installing headers soon and new mufflers / exhaust..My question, if I have the muffler shop install an H pipe, will this help the torque numbers if at all? I'm guessing it wouldn't help a stock 350...
Thanks.... |
11-18-2010, 05:12 PM | #2 |
Re: Dual Exhaust question
You are correct, on a stock to mild build, not much diff will be noticed. Unless I was chasing a noise problem, I would not spend the extra cash for an H pipe.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
11-18-2010, 07:14 PM | #3 | ||
Champagne Taste on Beer Budget
Headers will make any engine breath better by removing of spent exhaust gases with little restrictions. If we are talking long tube then YES more torque if shorties then maybe not so much.
Coming Soon: Project 1970 Country Truck |
11-18-2010, 07:21 PM | #4 |
The H-pipe on mine cost an extra $50.00, it sounds way better with than without, Imo.
I'm not as good as I once was, But I'm as good once as I ever was. |
11-18-2010, 08:52 PM | #5 |
11-18-2010, 08:56 PM | #6 | |
11-18-2010, 09:00 PM | #7 |
11-18-2010, 09:10 PM | #8 |
The H pipe will help the low/ midrange tork, as well as give your exhaust a nicer sound(also said to improve the mileage somewhat?). It wont make your stocker into a "speedracer", but IMO ,its worth adding(I have ran one on all of my trucks,& feel that its a good addition). crazyAl
http://community.webshots.com/user/hotrodhorn |
11-19-2010, 12:12 AM | #9 |
I have one on mine that i bought from Summit Racing for less then $30. I don't know about the performance, but it sure sounds good through turbo mufflers and 2 1/2 in pipe.
11-19-2010, 09:37 AM | #10 |
Parts and more parts
Everyone has an opinion, so here is what I have experienced. Over the years, I have found that the "H" or even better an "X" Pipe will make a difference in the torque of even a mild enigne. The exhaust flow is evened out and the resulting acceleration is smoother. The principal is to create a vortex to pull the exhaust gases out of the opposite side of the engine, thus making it flow better through the cylinders. The better flow out, the better the flow into the cylinders and the more efficient the engine becomes. I would not install any exhaust components without some form of connection between the two pipes. The cross-over even makes the exhasut note sound better and not so harsh and raspy.
Frank |
11-19-2010, 10:01 AM | #11 |
if you do add this I'd go with an x pipe . just have whatever set up you pick made tobe easily removed, as most cross under the tranny.. and if you have to work on it or ddrop it.. it's easier if it's easily removeble some like band clams come like ball and socket
fyi even the lowly stocker gets a few ftlb from these.. |
11-20-2010, 07:36 AM | #12 | ||
11-20-2010, 01:45 PM | #13 |
Cops, ha, catch me if you can!
This is my personal opinion, I have headers with a true dual exhaust (no X or H) and I love the sound of it when at WOT, talk about raspy, LOVE it. Cruising around town it almost sounds like it has a lumpy cam. I just don't know if the small increase in torque is something I would want to trade for the sound. You can always find power other places. It is all up to your personal preference.
72 C-10 Stepper 350/TH350 3.73 in the back Edelbrock intake and Carb Hooker Comp Headers 275/60R15 on Rallies Last edited by gonzo6869; 11-20-2010 at 01:46 PM. |
