Old 11-18-2010, 09:46 PM   #1
luis979motoring
luis979motoring's Avatar
OK, after countless days & nights searching...
I have decided to start a thread on what I am trying to do. I have a 68 c10. I want to convert it to 5 lug from the factory all drum 6 lug. What are the options? I have come to this conclusion. I can drop in a 73-87 C10 front crossmember. But will there be any noticable differences? Is it going to stick out more than ths factory 68? When we get to work on the rear, what all needs to be done? I have been told that swapping the axles out of a 73-76 c10(with the Same 12 bolt 8 7/8) rear end would work and getting there drum setup as well. Also does it matter if the rear ends are coil spring or leaf spring? thanks soo much for the help fellas. This forum has been such great help for me! hopefully you guys can help me out!
luis979motoring is offline   Reply With Quote
Old 11-18-2010, 09:56 PM   #2
justincat
Re: OK, after countless days & nights searching...
I did mine with ece kit. The back is easy. You just have to pull the cover and pull out the keys, and slide new ones back in. Ece sells a disk brack conversion for the front that comes with 5 lug rotors, and all the parts and directions to install it. Thats just one option. Ive never put later model parts on but ive heard of alot of people doing so.
justincat is offline   Reply With Quote
Old 11-18-2010, 10:02 PM   #3
joe b
You can use a 71-72 front crossmember rearend
joe b is offline   Reply With Quote
Old 11-18-2010, 10:12 PM   #4
qksilver
you don't have to change the crossmember to use the 73- front suspension parts. The 73 up crossmember will mean you can drop the oil pan easier other thasn that there isn't much difference in the crossmember. The 73 - parts are cheaper and ride a little better, to install the 73 up crossmember you will have to drill I think one or 2 holes to mount it but the rest will bolt in.
Steve
qksilver is offline   Reply With Quote
Old 11-19-2010, 10:10 AM   #5
mrhino
Iv done 3 conversions now. all you need is a front spindle from either 71-72 or 73-up, whatever spindle you choose get the matching ball joints, rotors and calipers and pads for it. The rear is a little more involved. You need to replace the axles however to my knowledge there are no 5 lug axle from a stock vehical that will work in your 68 12 bolt. Iv always pick up new axles from Moser engineering. then you can either get drum brake set up or convert it to disc. check out my build thread posts 7-9, and 79-82 shows front and rear
mrhino is offline   Reply With Quote
Old 11-19-2010, 11:19 AM   #6
Sammy
Classic trucks in Sep (i believe) had a article on converting your current 6 Lug axles to 5 lug by removing the axles having them redrilled and new studs installed. If you wanted to stay with rear stock drums that would be the cheapest conversion with the less work.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL"
"You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig."
ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629"
Sammy is offline   Reply With Quote
Old 11-20-2010, 04:15 AM   #7
raycow
There are no stock GM shafts that will convert your rear to 5 lug. As already pointed out, you can buy aftermarket 5 lug shafts or get your present shafts redrilled. One other option is to swap in a complete 71-72 rear end. This is a total bolt-in, but is about 1-1/2" wider than your present rear.
Ray
Live more responsibly. Eat lower on the food chain. Eat vegetarians.
raycow is offline   Reply With Quote
Old 11-22-2010, 02:47 AM   #8
luis979motoring
Thanks so much fellas for all the great help! I think I am going to go with Mrhino's route. save me some money for now. I am just going to go search for a 71-72 rear end for now. I plan on checking one out tomorow. thanks so much fellas!
Old 11-22-2010, 03:22 AM   #9
MistaGavin
MistaGavin's Avatar
What's the point to convert 6 lug to 5 lug?
MistaGavin is offline   Reply With Quote
Old 11-22-2010, 09:21 AM   #10
robzilla
robzilla's Avatar
Ray
no real issues with being 1 1/2" inches wider?
robzilla is offline   Reply With Quote
Old 11-22-2010, 11:15 AM   #11
dan42
dan42's Avatar
There is the perception that there is more of a rim selection with 5 lug. It used to be that you had to have 5 lug to switch to front discs, but you can get 6 lug front discs now.
'67 SWB Fleetside ZZ4/350/Tremec 5-speed/4link/Scott's IFS - and fun as heck! SOLD
Click here to support the board
Philippians 4: 6-7
dan42 is offline   Reply With Quote
Old 11-22-2010, 11:46 AM   #12
raycow
No issues with stock wheels/tires. If you are lowered and have wide tires, you will have to use wheels with suitable backspacing.
Ray
Old 12-01-2010, 11:18 PM   #13
luis979motoring
so does anyone know where i can find a 5 lug diff?
What i was thinking of doing is getting axles from a 72 chevy and swapping them into my 68 diff. will that work? does moser make axles that will swap directly into my current rear end? I have purchased all my front end stuff minus the spindles... but now i regret it since i couldve just got the big brake kits... oh well, right? thanks for the help fellas!!
Old 12-01-2010, 11:19 PM   #14
luis979motoring
** sorry double post of this ^^
Old 12-01-2010, 11:31 PM   #15
ksbrktracer
TNT-MOTORSPORTS
ksbrktracer's Avatar
No you cant just put 71-72 axles in the 68 rearend ... they are too wide, Have to buy axles the right length or change the complete rear axle assembly
ksbrktracer is offline   Reply With Quote
Old 12-02-2010, 12:21 AM   #16
luis979motoring
oh ok, thanks for that racer!!
Old 12-02-2010, 12:36 AM   #17
brad_man_72
the boat guy
brad_man_72's Avatar
I swapped in a rear end from a 76. They make all of the brackets to weld on then an adjustable panhard bar. I used a whole parts truck. Wheels, tires, steering linkage, control arms, spindles, master cylinder, pedal linkage, porportioning valve, rear end. Sold the engine and trans, and scrapped the body. Did I mention I made money on the deal...
or you can spend money and have nice, new, clean stuff to work with, that will probably work better and look nicer.
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck
66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate.
28, model a rpu project,
brad_man_72 is offline   Reply With Quote
Old 12-02-2010, 12:38 AM   #18
luis979motoring
was it coil or leaf spring?
Old 12-02-2010, 12:54 AM   #19
N2TRUX
Happy to be here
N2TRUX's Avatar
All 73-87's are leaf spring rear, and for point of reference take a look at this chart-
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 12-02-2010, 01:46 AM   #20
Rob68c10
I just got done stripping a 72 about 2 hours ago. Planning on swapping the front member and rear into my 68. Easy as pie.
Rob68c10 is offline   Reply With Quote
Old 12-02-2010, 01:49 AM   #21
luis979motoring
jealous. lol
N2, what i was wondering, is how did he manage to put the leaf spring rear end into the coil spring rear??
Old 12-02-2010, 06:41 AM   #22
mrhino
Yes, Moser does make 5 lug axles that will drop right in to your 68. No you cant put 72 axels into your 68. sure you can stick damn near any rear end under your truck, there will just be some cutting welding and grinding to switch your mounting brackets over. Moser will redrill your old axles as well, there is (or was) a price list on there website. Im thinking it was $60 a axle, I was thinking of doing that once but the bearing surface on my axles were tore up pretyy good. So I opted for new ones.
Old 12-02-2010, 08:47 AM   #23
trucks72
trucks72
trucks72's Avatar
Hey mrhino, when you changed the spindle over were the ball joints not a different size going through the lower control arm. I was just wondering what you did there.
trucks72 is offline   Reply With Quote
Old 12-02-2010, 09:06 AM   #24
mrhino
yea you need to put in ball joints, to match whatever spindle you use. i.e. if you use a 73 and up spindle you need 73-up ball joints. I personally use the 73- up stuff just because its move available, and in most cases its cheaper as well.
Old 12-02-2010, 01:47 PM   #25
ERASER5
ERASER5's Avatar
Luis, just some information, 68 factory rims will not work with 6 lug disc brakes. The inside shape of the rim will hit the caliper. All chevy truck 5 lug rims will be fine, as they were made for disc brakes starting in 71.
'70 GMC C1500 LWB
Power disc brakes. WooHoo!
Posi 6 Lug Dana 60
ERASER5 is offline   Reply With Quote
